StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-SC
Quicklinx: 949YWS00 Mfr#: SMFIBLCSC4
£18.78 ex VAT
£22.53 inc VAT
Connect fiber network devices for high-speed transfers with LSZH rated cable. The SMFIBLCSC4 4m LC to SC Single-Mode Duplex Fiber Cable features 9/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex single-mode applications.
This LC-SC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire - an ideal solution for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 9/125 (OS1) Single-Mode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
StarTech.com 4m Fiber Optic Cable - Single-Mode Duplex 9/125 - LSZH - LC/SC - OS1 - LC to SC Fiber Patch Cable (SMFIBLCSC4) - patch cable - 4 m - yellow
Patch cable - OS1
Duplex fibre optic
Molded
Length
4 m
Core / Cladding Diameter
9 / 125 micron
Connector
2 x SC single-mode - male
Connector (Second End)
2 x LC single-mode - male
Yellow
Network Cable Type
Patch cable - OS1
Duplex fibre optic
Jacket Material
Low Smoke Zero Halogen (LSZH)
9 / 125 micron
Molded
Length
4 m
Yellow
Connector
RoHS
