Split an HDMI audio/video source to two separate HDMI Displays, with support for HDMI 4K, and Power through a nearby USB port. The ST122HD4KU 2-port video splitter supports Ultra HD (4K) ensuring astonishing picture quality, four times the resolution of high-definition 1080p, while sharing a 4K HDMI video source between two HDMI displays.
The 4K splitter is backward compatible with previous HDMI revisions, supporting 1080p / 720p HDMI video resolution devices such as computers, Blu-ray players and cable TV set-top boxes. Even if you don't require 4K video today, the video splitter ensures you'll be ready to take advantage of tomorrow's display technology while still working with the devices you already have. Plus, this splitter supports 3D, enabling you to use the splitter with your stereoscopic 3D video source on active or passive 3D displays.
For a hassle-free setup you can power the HDMI splitter with the included USB cable, or power adapter depending on which is most convenient for you. Plus, the splitter features a built-in HDMI source cable, which lets you connect it directly to your HDMI source without the expense of additional cabling.
Effective resolution capability
This HDMI cable splitter supports video resolutions up to 3840 x 2160 at 30 Hz, ensuring high-quality visual output for various multimedia applications. -
Dual output functionality
Allows a single HDMI source to be displayed on two separate screens, making it suitable for presentations or multi-screen setups. -
Reliable power source
The external power adapter ensures stable operation, providing continuous power for optimal video performance without interruptions. -
Compliance with industry standards
Adheres to FCC and RoHS standards for safety and environmental responsibility, ensuring a reliable and safe product.
 - StarTech.com HDMI Cable Splitter - 2 Port - 4K 30Hz - Powered - HDMI Audio / Video Splitter - 1 in 2 Out - HDMI 1.4 - video/audio splitter - 2 ports
 - Video/audio splitter - 2 ports
- Subtype
 - HDMI
- Ports
 - 2 x HDMI
 - 5 cm x 62 cm x 1.8 cm
 - 78 g
 - 2-year warranty
- Designed For
 - P/N: ST121SHD50, SVA5M3NEUA
- Enclosure Type
 - Desktop
- Subtype
 - HDMI
- Ports
 - 2 x HDMI
- Max Resolution
 - 3840 x 2160 @ 30 Hz
 - 1 x HDMI input , 2 x HDMI output
- Power Device
 - External power adapter
- Cables Included
 - 1 x USB power cable
 - FCC, RoHS
 - 5 cm
 - 62 cm
 - 1.8 cm
 - 78 g
 - Limited warranty - 2 years
- Designed For
                        StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
                        StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable | In Stock | £5.05 |
                        StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio | In Stock | £89.31 |
                        StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier | In Stock | £68.05 |
                        StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £9.68 |
                        StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.48 |
                        StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) | In Stock | £90.68 |
                        StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.05 |
                        StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter | In Stock | £48.75 |
                        StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.21 |
                        StarTech.com 8-Port 4K 60Hz HDMI Splitter | In Stock | £132.02 |
                        StarTech.com HDMI Splitter - 4 Port - 4K 60Hz | In Stock | £53.52 |
                        StarTech.com 55-Bit Electric Precision Screwdriver Set | In Stock | £58.18 |
                        StarTech.com 2-Port HDMI Splitter, 4K 60Hz | In Stock | £50.05 |
