StarTech.com 2-Port HDMI Splitter, 4K 60Hz
Quicklinx: H3TZWS00 Mfr#: HDMI-SPLITTER-4K60UP
Type: HDMI
Ports: 2
31 In Stock
£50.05 ex VAT
£60.06 inc VAT
This 2-port HDMI splitter displays the same image from an HDMI video source onto two HDMI displays, with support for UHD 4K resolutions, HDR (High Dynamic Range), HDCP content, and 7.1 channel audio.
  • 4K 60Hz Resolution
    This 2-way HDMI splitter supports up to 4K 60Hz resolution and 4:4:4 chroma subsampling. Display 4K content on both your 4K displays or downscale the resolution to 1080p to support monitors with different resolutions, thanks to the built-in scaler. Ideal for environments containing displays of mixed resolutions.
  • USB Powered
    The splitter includes a 31inch (78cm) USB Micro-B to Type-A power cable and USB wall charger. If an outlet is not available or within reach, the USB power cable can be connected to a 5V 1A USB Type-A port.
  • Robust Installation Options
    This HDMI splitter supports active HDMI cables and HDMI extenders (sold separately), facilitating installations at a distance from the displays (e.g., within a remote AV component cabinet). The reset button enables hassle-free hot plug EDID detection, without the need of unplugging cables. The splitter features 8kV air and 6kV contact Electrostatic Discharge (ESD) protection, suitable for installation in a variety of environments. This product is backed for 2 years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 2-Port HDMI Splitter, 4K 60Hz HDMI 2.0 Video, 4K HDMI Splitter 1 In 2 Out, 1x2 HDMI Display/Output Splitter, HDR/HDCP - 20in (50cm) Built-in HDMI Cable, Powered via USB or Included Power Supply (HDMI-SPLITTER-4K60UP) - video/audio splitter - 2 ports
Video/audio splitter - 2 ports
Subtype
HDMI
Performance
Total bandwidth: 18 Gbps
Reset button, 7.1 channel audio support, EDID Management, auto scaler, 8KV ESD Protector (air-gap discharge), HDR support, 6KV ESD Protector (contact discharge), 4K UHD video streaming, 4:4:4 chroma subsampling support
HDCP 1.4, HDCP 2.2
AC 100-240 V 0.3 A
5.5 cm x 6.5 cm x 1.9 cm
92 g
Enclosure Type
Desktop
Subtype
HDMI
Performance
Max Resolution
4K @ 60 Hz
HDCP 1.4, HDCP 2.2
Status Indicators
Port status, power
1 x HDMI input Type A male , 2 x HDMI output Type A female , 1 x micro-USB Type B
External power adapter
Power Provided
DC 5 V - 1 A
AC 100-240 V
Electric Current Required
0.3 A
5 Watt
1 x HDMI cable - 50.8 cm , 1 x USB-A to Micro-USB Type B cable - 78 cm
RoHS, WEEE
5.5 cm
6.5 cm
1.9 cm
92 g
Shipping Width
19 cm
Shipping Depth
14.5 cm
Shipping Height
3 cm
Shipping Weight
168 g
Limited warranty - 2 years , Technical support - assistance - lifetime
70 °C
5 - 90% RH (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
80 °C
H3TZ StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £16.48
H3TZ StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £20.48
H3TZ StarTech.com 10ft Ultra High Speed HDMI 2.1 In Stock £23.74
H3TZ StarTech.com 16ft Ultra High Speed HDMI 2.1 In Stock £39.48
Type: HDMI
Ports: 2
