StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply w/ Active PFC
Quicklinx: 93JVWS00 Mfr#: ATX2PW430WH
Build or upgrade a computer system with an energy efficient and reliable 430 Watt ATX power supply. The ATX2PW430WH 430 Watt 80 Plus Power Supply offers an energy efficient replacement or upgrade for powering your desktop PC. Operating at a minimum of 80% efficiency between 20% and 100% load, 80 Plus power supplies deliver a significant improvement over standard-efficiency power supplies that helps reduce energy consumption and cost of operation.
This versatile power supply is equipped to support AMD or Intel CPU-based servers and workstations with a combined 20/24-pin motherboard connection, and an 8-pin EPS connector.
StarTech.com 430 Watt ATX12V 2.3 80 Plus Power Supply w/ Active PFC - power supply - 430 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V 2.92
80 PLUS Certification
80 PLUS
Input Voltage
AC 115/230 V
Output Voltage
+3.3, ±5, ±12 V
Power Capacity
430 Watt
Output Current
+12V1 - 37 A , +12V2 - 37 A , +12V3 - 37 A , +12V4 - 37 A , +3.3V - 20 A , +5V - 20 A , -12V - 0.5 A , +5VSB - 2.5 A , -5V - 37 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 4 pin ATX12V connector , 1 x 8 pin PCI Express power , 4 x 15 pin Serial ATA power , 3 x 4 PIN internal power
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
PSU Form Factor
ATX
Input Voltage
AC 115/230 V
Input Voltage Range
AC 110 - 240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, ±5, ±12 V
Power Capacity
430 Watt
Output Current
80 PLUS
Cooling System
120 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, quad 12V rails, short-circuit protection, non-modular
UL, FCC, RoHS
10 - 90%
15 cm
14 cm
8.6 cm
