StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks
Quicklinx: 97RHWS00 Mfr#: 4POSTRACK42
U Height: 42U
Depth (mm): 59.18cm
Type: Floor standing
Width (mm): 60cm
18 In Stock
£203.32 ex VAT
£243.98 inc VAT
Store your servers, network and telecommunications equipment in this adjustable 42U open-frame rack. The 4POSTRACK42 42U Server Rack lets you store your servers, network and telecommunications equipment in a sturdy, adjustable depth open-frame rack.
Designed with ease of use in mind, this 42U rack offers easy-to-read markings for both rack units (U) and depth, with a wide range of mounting depth adjustments (22 - 40in) that make it easy to adapt the rack to fit your equipment.
This durable 4-post rack supports a static loading capacity of up to 1320lbs (600kg), and offers compliance with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494) for a universal design that's compatible with most rack equipment.
For a complete rack solution that saves you time and hassle, the rack includes optional accessories such as casters, leveling feet and cable management hooks. The base is also pre-drilled for securing the rack to the floor if needed, providing you with many options to customize the rack to fit your environment.
  • Steel construction
    Manufactured from high-quality steel, this server rack is designed to withstand heavy loads and provide support for various server equipment.
  • Storage capacity
    The 42U high frame offers space for mounting servers and other network devices, accommodating the needs of any expanding IT infrastructure.
  • Cable management
    Equipped with 24 cable management hooks, this server rack allows for organization of cables, minimizing clutter and enhancing airflow around equipment.
  • Components included
    The rack comes with a complete set of mounting hardware, including screws and brackets, ensuring an easier installation process and customizable setup options.
  • Safety compliance
    This product adheres to multiple safety standards such as RoHS and IEC, ensuring reliability and environmental safety during use.
StarTech.com 42U 19" Open Frame Server Rack, 4 Post Adjustable Depth 23-41" Mobile, Free Standing Rolling Network/Computer Equipment Data Rack, Dell PowerEdge, HP ProLiant ThinkServer - Adjustable Server Rack (4POSTRACK42) - rack - 42U
Rack
Package Content
16 M6 screws, 4 vertical rack rails, 24 mounting screws, 2 base brackets, 2 top brackets, 48 M8 bolts, 8 corner sections, 48 M8 washers, M8 (13mm) wrench, 50 PVC cup washers, 24 cable management hooks, 4 casters, 4 x levelling feet, 32 M6 flat washers, 16 M6 flange nuts, 50 M6 screws, 50 M6 cage nuts
Height (Rack Units)
42U
Product Material
Steel
60 cm x 59.18 cm x 197.1 cm
38.5 kg
P/N: CABCAGENT62B, CABCAGENTS62, CABCAGENUT2B, CABCAGENUT6B, CABCAGENUTS2, CABCAGENUTSB, CABSCREWM52B, CABSCREWM5B, CABSCREWM62B, CABSCREWM6B, CABSCREWSB, CABSCREWSM5, CABSCREWSM5B, CABSCREWSM62, CABSCREWSM6B, CABSCRWS1224, CABSCRWSM62B
Rack
Product Material
Steel
Package Content
Height (Rack Units)
42U
60 cm
59.18 cm
197.1 cm
38.5 kg
Weight Limit
600 kg
RoHS, DIN 41494, IEC 60297-3-100
Limited warranty: - 2 years
97RH StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £92.31
97RH StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £44.73
97RH StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £75.26
97RH StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
97RH StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
97RH StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.44
97RH StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £452.75
97RH StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.39
97RH StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.99
97RH StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
97RH StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
97RH StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.06
97RH StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £88.98
97RH StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £514.22
97RH StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £273.74
97RH StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £309.46
97RH StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £600.89
97RH StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £84.75
97RH StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £97.41
97RH StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £61.35
97RH StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £70.88
97RH StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £75.13
97RH StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £17.22
97RH StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £71.34
97RH StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.01
97RH StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
97RH StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £43.20
97RH StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £36.09
97RH StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £50.11
97RH StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
97RH StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.23
97RH StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.20
97RH StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.24
97RH StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks In Stock £203.32
97RH StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £154.86
97RH StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £156.90
97RH StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
97RH StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.31
97RH StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £192.50
97RH StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £22.90
97RH StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £165.22
97RH StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.06
97RH StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £29.89
97RH StarTech.com 50 Pkg M6 Cage Nuts In Stock £19.69
97RH StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
97RH StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
97RH StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £52.24
97RH StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £27.56
97RH StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
97RH StarTech.com 100 Pkg M5 Mounting Screws In Stock £30.51
97RH StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.16
97RH StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.89
97RH StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.45
97RH StarTech.com 19in Cable Management Panel In Stock £23.58
97RH StarTech.com Vented 1U Rack Shelf - 10in In Stock £20.54
97RH StarTech.com 15U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £187.45
97RH StarTech.com 18U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £191.84
97RH StarTech.com 8U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £148.60
97RH StarTech.com Heavy Duty Casters for Server Racks/Cabinets - Set of 4 In Stock £35.72
97RH StarTech.com M6 Mounting Screws 50Pack In Stock £16.78
U Height: 42U
Depth (mm): 59.18cm
Width (mm): 60cm
