Store your servers, network and telecommunications equipment in this adjustable 42U open-frame rack. The 4POSTRACK42 42U Server Rack lets you store your servers, network and telecommunications equipment in a sturdy, adjustable depth open-frame rack.
Designed with ease of use in mind, this 42U rack offers easy-to-read markings for both rack units (U) and depth, with a wide range of mounting depth adjustments (22 - 40in) that make it easy to adapt the rack to fit your equipment.
This durable 4-post rack supports a static loading capacity of up to 1320lbs (600kg), and offers compliance with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494) for a universal design that's compatible with most rack equipment.
For a complete rack solution that saves you time and hassle, the rack includes optional accessories such as casters, leveling feet and cable management hooks. The base is also pre-drilled for securing the rack to the floor if needed, providing you with many options to customize the rack to fit your environment.
- StarTech.com 42U 19" Open Frame Server Rack, 4 Post Adjustable Depth 23-41" Mobile, Free Standing Rolling Network/Computer Equipment Data Rack, Dell PowerEdge, HP ProLiant ThinkServer - Adjustable Server Rack (4POSTRACK42) - rack - 42U
- Product Type
- Rack
- Package Content
- 16 M6 screws, 4 vertical rack rails, 24 mounting screws, 2 base brackets, 2 top brackets, 48 M8 bolts, 8 corner sections, 48 M8 washers, M8 (13mm) wrench, 50 PVC cup washers, 24 cable management hooks, 4 casters, 4 x levelling feet, 32 M6 flat washers, 16 M6 flange nuts, 50 M6 screws, 50 M6 cage nuts
- Black
- Height (Rack Units)
- 42U
- Product Material
- Steel
- 60 cm x 59.18 cm x 197.1 cm
- 38.5 kg
- 2-year warranty
- Designed For
- P/N: CABCAGENT62B, CABCAGENTS62, CABCAGENUT2B, CABCAGENUT6B, CABCAGENUTS2, CABCAGENUTSB, CABSCREWM52B, CABSCREWM5B, CABSCREWM62B, CABSCREWM6B, CABSCREWSB, CABSCREWSM5, CABSCREWSM5B, CABSCREWSM62, CABSCREWSM6B, CABSCRWS1224, CABSCRWSM62B
- Product Type
- Rack
- Product Material
- Steel
- Package Content
- 42U
- 60 cm
- 59.18 cm
- 197.1 cm
- 38.5 kg
- Black
- Weight Limit
- 600 kg
- RoHS, DIN 41494, IEC 60297-3-100
- Limited warranty: - 2 years
- Designed For
StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £488.55 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £96.93 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £84.93 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £12.34 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.51 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £31.10 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £477.22 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £335.92 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.45 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.56 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.09 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.23 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £25.89 |
StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf | In Stock | £92.13 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £542.00 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £284.45 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £317.76 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £635.38 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £86.73 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £101.34 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £63.29 |
StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £77.90 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £33.04 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £73.91 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £82.73 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £55.31 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £44.71 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £37.48 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £52.08 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.40 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.45 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £39.94 |
StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks | In Stock | £210.18 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg | In Stock | £162.10 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.00 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.96 |
StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £199.11 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £23.35 |
StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £170.86 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £57.09 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.44 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £26.80 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £20.46 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £28.99 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £15.59 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £54.01 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £29.06 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £16.04 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.99 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.75 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.29 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £28.49 |
StarTech.com 19in Cable Management Panel | In Stock | £23.30 |
StarTech.com Vented 1U Rack Shelf - 10in | In Stock | £21.36 |
StarTech.com 15U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth | In Stock | £160.05 |
StarTech.com 18U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth | In Stock | £198.70 |
StarTech.com 8U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth | In Stock | £153.36 |
StarTech.com Heavy Duty Casters for Server Racks/Cabinets - Set of 4 | In Stock | £36.91 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.78 |
