StarTech.com 4-to-4 USB 3.0 Peripheral Sharing Switch
Quicklinx: DZ74WS00 Mfr#: HBS304A24A
13 In Stock
£75.42 ex VAT
£90.50 inc VAT
Share up to four USB 3.0 devices between four different computers. This 4x4 USB 3.0 peripheral sharing switch lets you share four USB 3.0 peripheral devices between four different computers, providing a cost-effective way to create a more productive, space-efficient work area.
Save the expense of purchasing duplicate peripherals, by sharing devices (such as USB printers, portable hard drives, mouse and keyboard) with up to four computers. The USB switch also lets you avoid having to swap cables from one system to another, saving time and effort.
Enjoy fast data transfers to and from your shared peripheral devices. The USB switch supports USB 3.0 (up to 5Gbps), providing high-bandwidth support for devices like external hard drives and webcams. The USB 3.0 switch is also backward compatible with USB 2.0/1.1 and works with older devices.
The plug-and-play USB switch is easy to use, with no drivers or software required. It features a remote port selector that lets you switch peripheral devices from one computer to another with the press of a button. The LED indicates the active computer.
The switch's compact design takes up minimal desk space and it's USB-powered.
The 4-port USB switch can also be connected to a USB hub or docking station, to expand the number of shared devices.
  • Robust Connectivity
    The USB 3.0 Peripheral Sharing Switch allows simultaneous connection of up to 4 computers, making it easier to share devices like printers, scanners, and external drives without physical reconnections.
  • High-Speed Data Transfer
    Utilizing USB 3.0 technology, this switch ensures that data transfers happen swiftly, enhancing overall efficiency when switching between devices.
  • User-Friendly Design
    Equipped with a remote port selector, users can easily switch between connected devices, streamlining their workflow without needing to access the switch physically.
  • Durable Construction
    With a strong plastic housing, this switch is designed to withstand everyday use while maintaining reliable performance over time.
  • Safe Operation
    Incorporating over-current protection, the USB switch safeguards connected devices against potential electrical issues, ensuring a secure environment for use.
StarTech.com USB 3.0 Peripheral Sharing Switch - 4 USB 3.0 x 4 Computers - Mac / Windows / Linux - USB A/B Switch - USB Switch (HBS304A24A) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
8 x SuperSpeed USB 3.0
USB powered, plastic housing, over-current protection
9.4 cm x 9.4 cm x 2.6 cm
130 g
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 3.0 Type A , 1 x USB 3.0 Type B , 1 x micro-USB (power only) Type B
2 x USB-A to USB-B cable - 1.2 m , 2 x USB-A to USB-B cable - 1.8 cm , 1 x remote port selector - 1.8 cm
9.4 cm
9.4 cm
2.6 cm
130 g
Shipping Weight
650 g
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Humidity Range Storage
0 - 80%
