StarTech.com 4-Port KM Switch, USB Switch
Quicklinx: HMPDWS00 Mfr#: P4A20132-KM-SWITCH
Type: Keyboard/mouse switch
Connectivity: USB
Ports: 2
11 In Stock
£237.73 ex VAT
£285.27 inc VAT
This Keyboard and Mouse (KM) Switch enables switching a single keyboard and mouse between multiple computers using mouse roaming, allowing users to seamlessly move the cursor across multiple screens (i.e., one monitor per computer).
  • Mouse Roaming
    Switch between computers by moving the mouse between monitors, without the need for hotkeys or physical buttons, enabling uninterrupted workflow and increased efficiency. Hotkey and push-button switching are universally compatible. Mouse Roaming is supported by most major desktop operating systems, including Windows, macOS, and Linux.
  • Preset Monitor Layouts
    To accommodate various physical monitor setups, there are six preset display configurations available. This allows for smooth mouse movement across host monitors.
  • Thoughtful Design
    Hotkeys enable listening to audio from one computer while controlling another. USB audio and 3.5mm pass-through are available, and LEDs provide visual port selection status, while an audible buzzer confirms hotkey selection. Note: On computers with multiple monitors connected, mouse/keyboard operation is limited to the primary display
StarTech.com 4-Port KM Switch with Mouse Roaming, USB Switch for Keyboard/Mouse, 3.5mm and USB Audio, Peripheral Sharing for 4 Computers, USB 3.0 Switcher, TAA Compliant - Hotkey/Pushbutton Switching (P4A20132-KM-SWITCH) - keyboard/mouse switch - 2 ports - TAA Compliant
Keyboard/mouse switch - 2 ports
Subtype
USB
KVM Users Qty
1 local user
Steel housing, mouse roaming
AC 100-240 V
13 cm x 22 cm x 3.4 cm
800 g
TAA Compliant
Enclosure Type
Desktop
Subtype
USB
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Status Indicators
Status
4 x USB 3.2 Gen 1 Type B host , 4 x headphones mini-jack host , 2 x USB 3.2 Gen 1 Type A console , 3 x USB 2.0 Type A console , 1 x headphones mini-jack console , 1 x headphones mini-jack female , 1 x microphone mini-jack female
External power adapter
Power Provided
DC 12 V - 5 A
AC 100-240 V
0.1 Watt
MTBF
156,000 hours
RoHS
TAA Compliant
13 cm
22 cm
3.4 cm
800 g
Shipping Width
29.5 cm
Shipping Depth
24.5 cm
Shipping Height
6.3 cm
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
HMPD StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
HMPD StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £10.30
HMPD StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.07
HMPD StarTech.com 2m 6ft USB 3.0 C to B Cable In Stock £14.63
Connectivity: USB
Ports: 2
