StarTech.com 4-Slot PCIe Expansion Chassis
Quicklinx: H1T0WS00 Mfr#: 4PCIE-PCIE-ENCLOSURE
  • Expansion chassis for PCIe cards
    Increase the PCI-e slot count of a desktop computer or server; Add four external PCIe x1 slots; PCI Express 2.0 x2 proprietary USB-C Host Card with locking port; 5.9ft (1.8m) USB-C locking cable included.
  • Rugged construction
    PCI Express expansion box is built with SECC steel to withstand harsh conditions and up to 140°F (60°C); Vented chassis for cooling; Quiet operation; Power adapter (12V 3A) included, terminal block port (12-24 VDC) available.
  • Hassle free upgrades
    Connect add-on cards to a host system with limited expansion slots; Implement fast deployments and reduce the cost and downtime required to configure an existing or new host system.
  • Compatibility
    This PCIe expansion chassis is OS independent and requires no additional software; Windows, macOS, and Linux are supported; Installed add-on card may require additional drivers and specific supported OS; Not meant to be used with GPUs.
  • The IT pro's choice
    Designed and built for IT Professionals, this external PCIe expansion chassis for desktop is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 4-Slot PCIe Expansion Chassis with PCIe x2 Host Card, PCIe 2.0 - 10Gbps, External PCIe Slots for Desktops/Servers, PCI Express Expansion Box/Adapter, 4 PCIe x1 Slots - system bus extender
System bus extender
41.1 cm x 13.8 cm x 14.3 cm
2.3 kg
Power adapter AC 100-240 V
System bus extender
41.1 cm
13.8 cm
14.3 cm
2.3 kg
Enclosure Colour
Expansion Slots
4 (total) / 4 (free) x PCI Express 2.0 x1
1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x power - terminal block
Compatible Slots
1 x PCI Express 2.0 x2
1 x USB-C screw-lock cable - external - 1.8 m
PCIe x2 to USB-C host card, low profile bracket, terminal block connector, 2 x mounting brackets, screws
Asmedia ASM1806 chipset, 2 LED indicators, up to 10Gbps data transfer, vented, wake on LAN, PCI Express Advanced Error Reporting (AER), EndPoint Cyclic Redundancy Check (ECRC), full-length, on/off power switch
WEEE, RCM, SECC
Power adapter
AC 100-240 V
Microsoft Windows, Apple MacOS, Linux
Limited warranty - 2 years , Technical support - assistance - lifetime
Shipping Width
42 cm
Shipping Depth
20 cm
Shipping Height
24 cm
Shipping Weight
6 kg
60 °C
H1T0 StarTech.com 1-Port Parallel PCIe Card, PCI Express to Parallel DB25 LPT In Stock £19.36
