StarTech.com 4 Port USB to Serial Hub
Quicklinx: CFQZWS00 Mfr#: ICUSB2324
Type: Serial adapter
Compatibility: PC, Mac
Interface: USB
11 In Stock
£78.51 ex VAT
£94.21 inc VAT
This USB to RS-232 serial hub lets you connect RS-232 serial devices to your laptop or desktop computer through a single USB port, as though the computer offered built-on DB9M serial connectors. The RS-232 serial hub is compactly designed to preserve valuable workspace, and is bus-powered to eliminate the need for an external power adapter.
  • Versatile Connectivity
    The adapter features four 9-pin D-Sub (DB-9) male ports, allowing multiple RS-232 devices to connect simultaneously. This versatility ensures management of several serial connections through one USB interface.
  • Robust Environmental Support
    This adapter operates in a temperature range of 0°C to 55°C and can function effectively in environments with humidity levels from 5% to 95%. This makes it suitable for various operating conditions.
  • High Data Transfer Rate
    With a data transfer rate of 115 Kbps, the adapter ensures efficient communication between connected devices, minimizing latency and maximizing productivity.
  • Compliance Standards
    The adapter meets FCC and RoHS compliance standards, assuring users of its safety and environmental responsibility in usage within different contexts.
  • Practical Cable Length
    The 1.8 m USB cable provides ample length, allowing flexibility in arrangements and setups without compromising on connectivity quality.
StarTech.com 4 Port USB to Serial RS232 Adapter - DB9M - RS232 Extension - Serial to USB (ICUSB2324) - serial adapter - USB - RS-232 x 4
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232 x 4
RS-232
Data Transfer Rate
115 Kbps
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
Serial adapter
External
USB
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
115 Kbps
4 x RS-232 - 9 pin D-Sub (DB-9) - male
1 x USB cable (external) - 1.8 m
FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - lifetime
55 °C
5 - 95%
CFQZ StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.73
CFQZ StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £31.73
CFQZ StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M In Stock £13.22
CFQZ StarTech.com 24in Internal USB Motherboard Header to Serial RS232 Adapter In Stock £7.93
CFQZ StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.85
CFQZ StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £45.96
CFQZ StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter In Stock £46.21
CFQZ StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M In Stock £20.11
CFQZ StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £94.31
CFQZ StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £26.02
CFQZ StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £88.60
CFQZ StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £151.80
CFQZ StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.42
CFQZ StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.14
CFQZ StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.35
CFQZ StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.16
CFQZ StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.77
CFQZ StarTech.com USB to RS232 Serial Adapter In Stock £16.28
CFQZ StarTech.com 16-Port USB-Serial Adapter Hub In Stock £403.98
CFQZ StarTech.com 4 Port USB to Serial Hub In Stock £78.51
CFQZ StarTech.com USB C to RS232 Cable In Stock £21.66
CFQZ StarTech.com 4-Port USB to Serial Adapter In Stock £212.24
Compatibility: PC
Compatibility: Mac
Interface: USB
