StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F
Quicklinx: 8G42WS00 Mfr#: MXT1001MBK
Length: 1m
More than 50 In Stock
£4.16 ex VAT
£4.99 inc VAT
Extend the connection between your DB9 serial devices by up to 1m. The MXT1001MBK Black Serial Extension Cable (1m) features one DB9 male connector and one DB9 female connector, providing a high quality extension for your RS232 serial devices, which enables you to position your peripheral devices as needed.
  • Reliable connectivity
    This serial extension cable features a male 9-pin D-Sub connector on one end and a female version on the opposite end, ensuring effective connection for devices needing DB9 interfaces.
  • Durable construction
    Constructed with a shielded design and 28 AWG wire, this cable provides robust performance and long-lasting durability, accommodating various use cases.
  • Nickel-plated connectors
    The connectors are nickel-plated, which helps prevent corrosion and improves signal quality during data transmission.
  • Environmentally friendly
    This product complies with RoHS standards, taking a step towards reducing harmful materials and promoting sustainability in electronics.
StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F (MXT1001MBK) - serial extension cable - DB-9 to DB-9 - 1 m
Serial extension cable
Shielded
Length
1 m
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
P/N: 1P3FPC-USB-SERIAL, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232IS, ICUSB232PRO, ICUSB232V2
Shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1 m
Connector
RoHS
8G42 StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.16
8G42 StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.95
8G42 StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.35
Length: 1m
