Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
StarTech.com 4-Port USB C Hub with On/Off
Quicklinx: DQZ1WS00 Mfr#: HB30C4AIB
Type: USB Hub
Interface: USB
Speed: 5Gbps
Ports: 4
Form Factor: External
Hurry, only 3 left in stock!
£26.39 ex VAT
£31.66 inc VAT
This portable USB-C hub gives you an easy way to add four USB 3.0 Type-A ports to your USB-C equipped laptop, tablet or smartphone, with individual power switches to conserve power. The USB-C to USB 3.0 hub plugs easily into your laptop's USB Type-C or Thunderbolt 3 port. Plus, it's bus-powered for easy portability.
Use your existing USB 3.0 devices such as flash drives, mouse, keyboard and external hard drives. The 4-port USB 3.0 hub converts your computer's USB-C port into four USB 3.0 (Type-A ports), and it's backward compatible with your older USB 2.0 devices. (USB 3.0 is also known as USB 3.1 Gen 1.)
Each USB port on the USB Type-C hub has its own power switch so you can turn off devices when they're not in use. That means you can better manage power consumption for your USB devices, without having to physically disconnect the device or cable.
With its compact, lightweight design, this USB hub is designed for portable use. The versatile USB-C to USB hub is bus-powered, which means it draws its power directly from your computer's USB-C port, with no need for an external power adapter. You can travel lighter with fewer cables to carry with you.
The 4-Port USB-C hub installs automatically once you connect it to your laptop, so you can be up and running in seconds.
StarTech.com 4 Port USB C Hub, USB-C to 4x USB 3.0 Type-A Ports with Individual On/Off Port Switches, SuperSpeed 5Gbps USB 3.1/3.2 Gen 1, USB Bus Powered, Portable, 10" Attached Cable - Windows/macOS/Linux (HB30C4AIB) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 3.1 Gen 1
USB powered, on/off switches
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 1
3.49 cm x 8.5 cm x 1.92 cm
Apple MacOS, Linux, Microsoft Windows
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 3.1 Gen 1
X VIA Labs VL817
Status Indicators
4 x USB 3.1 Gen 1 Type A
1 x USB-C 3.1 cable - 25 cm
FCC, RoHS, UASP (USB Attached SCSI Protocol)
3.49 cm
8.5 cm
1.92 cm
55 °C
20 - 80% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
DQZ1 StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.71
DQZ1 StarTech.com 1m USB 3 Cable Right Angle BK In Stock £7.23
DQZ1 StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.61
DQZ1 StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £9.41
DQZ1 StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.62
DQZ1 StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.11
DQZ1 StarTech.com 6in USB 3.0 Extension Cable In Stock £5.41
DQZ1 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
DQZ1 StarTech.com 3ft Slim Micro USB 3.0 Cable In Stock £9.00
DQZ1 StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £30.59
DQZ1 StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £43.58
DQZ1 StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £25.84
DQZ1 StarTech.com 4 Port USB C Hub - C to C & A In Stock £26.36
DQZ1 StarTech.com 7 Port USB C Hub - C to C & A In Stock £66.79
DQZ1 StarTech.com 4-Port USB 3.0 Hub with On/Off In Stock £24.24
DQZ1 StarTech.com 4-Port USB-C Hub, 100W PD In Stock £38.06
DQZ1 StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £31.91
Type: USB Hub
Interface: USB
Speed: 5Gbps
Ports: 4
