StarTech.com 4 Port USB C Hub - C to C & A
Quicklinx: CZCTWS00 Mfr#: HB30C3A1CFBW
Type: USB Hub
Interface: USB 3.1 Type C
Speed: 5Gbps
Ports: 4
Form Factor: External
47 In Stock
£26.36 ex VAT
£31.63 inc VAT
Turn a USB Type-C port on your laptop into three USB Type-A ports (5Gbps) and one USB Type-C port. This 4-port USB 3.0 hub lets you connect a wider range of peripherals to your MacBook Pro, MacBook and other USB-C laptops. The hub expands your laptop or desktop connectivity by enabling you to connect both USB-A and USB-C devices through a single USB Type-C or Thunderbolt 3 port.
Extend the life of your current USB 3.0 devices and take advantage of newer devices that feature USB-C.
This USB-C hub lets you expand your USB connection options using the USB-C port on your computer. It offers three USB-A ports and one USB-C port, so you can connect traditional USB devices as well as newer USB-C devices to your USB-C laptop.
You can travel lighter, with a single USB-C adapter that lets you connect virtually any USB peripheral.
With its compact and rugged design, you can take this portable USB 3.0 hub anywhere you go. Because it's so compact, it's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation. The hub is ideal for use in hot-desk or BYOD (Bring Your Own Device) environments.
For portable applications, having the integrated host (USB-C) cable means one less thing to remember to carry with you.
This USB-C expansion hub is multi-platform compatible, which means it will work with a wide range of operating systems such as Windows, macOS, Linux and Chrome OS . It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
  • Versatile Connectivity
    This hub provides a combination of 1 USB-C and 3 USB-A ports, accommodating a variety of devices while enhancing productivity.
  • High-Speed Data Transfer
    Experience efficient data transfer with support for SuperSpeed USB 3.0, reaching speeds up to 5 Gbps, ideal for data-intensive applications.
  • Reliable Plug-and-Play Operation
    The hub's user-friendly design eliminates the need for software installation, ensuring a seamless experience right out of the box.
  • Compact and Efficient Design
    With its compact USB-C cable of 11.4 cm, this hub minimizes clutter while enabling easy access to multiple ports in any setup.
  • Temperature Resistance
    Designed to operate effectively within a range of 0 to 60 degrees Celsius, this hub remains reliable in various environments.
StarTech.com 4 Port USB C Hub with 1x USB-C & 3x USB-A Ports (SuperSpeed 5Gbps), USB Bus Powered, Compact Portable/Laptop USB 3.0 Adapter Hub, USB 3.1 Gen 1/USB 3.2 Gen 1 Type-C Hub, White - Windows/macOS/Linux (HB30C3A1CFBW) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x USB 3.1
USB powered
USB 1.1, USB 2.0, USB 3.0, USB 3.1
4 cm x 7.5 cm x 1.3 cm
33 g
White
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
X Genesys Logic GL3523
Status Indicators
3 x USB 3.0 Type A , 1 x USB 3.0 Type C
White
1 x USB-C cable - 11.4 cm
Plug and Play, FCC, RoHS, WEEE
4 cm
7.5 cm
1.3 cm
33 g
60 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
CZCT StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £19.33
CZCT StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £20.75
CZCT StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £30.59
CZCT StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £8.64
CZCT StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.01
CZCT StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.29
CZCT StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.27
CZCT StarTech.com 2m 6ft USB 2.0 USB-C Cable In Stock £11.19
CZCT StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £27.64
CZCT StarTech.com 4 Port USB C Hub - C to C & A In Stock £26.36
CZCT StarTech.com 4-Port USB-C Hub - USB 3.1 In Stock £34.22
CZCT StarTech.com 4-Port USB 3.0 Hub with On/Off In Stock £24.24
CZCT StarTech.com 4-Port USB-C Hub, 100W PD In Stock £38.06
CZCT StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £31.91
Type: USB Hub
Speed: 5Gbps
Ports: 4
