StarTech.com 4 Port USB C Hub 10Gbps
Quicklinx: GJJFWS00 Mfr#: HB31C2A2CME
Type: USB
Ports: 4
Data Transfer Rate: [N/A]
Managed: No
POE: No
Hurry, only 2 left in stock!
£135.21 ex VAT
£162.25 inc VAT
  • Expands the Connectivity of Your Computer for Industrial Applications
    With this USB-C hub you can connect two USB-A devices, and two USB-C devices, to a single USB-C or USB-A port on your host device. The hub supports USB 3.2 Gen 2 (10 Gbps), and is backward compatible with USB 3.2 Gen 1 (5 Gbps) and USB 2.0 (480 Mbps). Note: USB 3.2 Gen 2 (10 Gbps) is also known as USB 3.1 Gen 2 (10 Gbps), USB 3.2 Gen 1 (5 Gbps) is also know as USB 3.1 Gen 1 (5 Gbps), and USB 3.0 (5 Gbps).
  • Powers and Charges Your Connected Devices
    The USB hub is self powered using either the included 36W (12V/3A) AC to DC power adapter, or the built-in terminal block connector that supports a 7-24V DC input. The hub shares up to 30W of power between connected devices and each port supports BC 1.2 providing 12W (2.4A) of power on all ports up to a 30W draw.
  • Ideal for Use in Industrial Environments
    This USB hub has a rugged-metal enclosure with built-in mounting ears that enable you to mount it to any wall or surface. The hub features 15kV Air and 8kV Contact electrostatic discharge (ESD) protection. Each port on the Hub has a screw lock, avoiding the possibility of accidental cable disconnection, and a 3.3 ft. (1m) USB-C host cable, and a 3.3 ft. (1 m) USB-A host cable is included that features a locking screw.
  • Wide Device Compatibility
    The USB hub is OS independent ensuring support on a wide range of platforms including Windows, macOS, Linux, iPadOS, Chrome OS and Android. HB31C2A2CME is backed by a StarTech.com 2-year warranty and free lifetime 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
StarTech.com 4 Port USB C Hub 10Gbps, Metal Industrial USB-C Hub, 2x USB-C & 2x USB-A, ESD Surge Protection, USB-C or USB-A Host, Self-Powered, Mountable USB 3.1 Gen 2 Type-C Hub - Commercial/Rugged USB Hub - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
2 x USB 3.2 Gen 2 + 2 x USB-C 3.2 Gen 2
Screw lock, metal housing, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge)
USB 2.0, USB 3.0, USB 3.1 Gen 1, USB 3.1 Gen 2, USB 3.2 Gen 2, USB 3.2 Gen 1, Battery Charging 1.2
AC 100-240 V
5.96 cm x 15.2 cm x 2.35 cm
280 g
Australia, Japan, New Zealand, North America, United Kingdom, Europe
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Status Indicators
Power, status
2 x USB 3.2 Gen 2 Type A , 2 x USB 3.2 Gen 2 Type C
External power adapter
Power Provided
DC 12 V - 3 A
AC 100-240 V
36 Watt
1 x USB to USB-C cable - 1 m , 1 x USB-C to USB-A cable - 1 m
FCC, RoHS, UASP (USB Attached SCSI Protocol)
5.96 cm
15.2 cm
2.35 cm
280 g
Shipping Width
29 cm
Shipping Depth
19 cm
Shipping Height
6.7 cm
Shipping Weight
1.3 kg
55 °C
5 - 95%
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
GJJF StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.94
GJJF StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £10.90
GJJF StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.82
GJJF StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.98
GJJF StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £26.96
GJJF StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £9.70
GJJF StarTech.com Industrial USB 3.0 Hub In Stock £360.13
Type: USB
Ports: 4
Managed: No
POE: No
