StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M
Quicklinx: 8WSKWS00 Mfr#: USB3CAUB1M
Length: 1m
More than 50 In Stock
£10.90 ex VAT
£13.08 inc VAT
Connect your Micro-B USB 3.0 devices, with this high-quality USB 3.0 certified cable. The USB3CAUB1M 1m USB 3.0 Micro B cable provides a high quality connection between your Micro USB-equipped USB 3.0 devices (e.g. card reader, video capture device, hard drive enclosure, etc.) and a USB-capable computer.
This cable is USB-IF certified to USB 3.0 specifications, guaranteeing a dependable, long-lasting connection to your Micro USB devices.
StarTech.com 1m 3 ft Certified SuperSpeed USB 3.0 A to Micro B Cable Cord - USB 3 Micro B Cable - 1x USB A (M), 1x USB Micro B (M) - Black (USB3CAUB1M) - USB cable - Micro-USB Type B to USB Type A - 1 m
USB cable
Shielded
5 Gbps data rate
Length
1 m
Connector
10 pin Micro-USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: DKT30CVAGPD, HB30A4AIB, HB30AM4AB, HB30C4AIB, HB31C2A2CME, HB31C3A1CME, HB31C4AB, HBS304A24A, S2510BPU337, S251BU31REM, S251BU31REMD, S251SMU33EP, ST7C51224, ST7C51224EU, ST7CU35122
USB cable
Shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
5 Gbps data rate
Length
1 m
Connector
USB 3.0, RoHS
8WSK StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £11.11
8WSK StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.86
8WSK StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £10.90
Length: 1m
