StarTech.com 4 Port USB-C Hub - C to C & A
Quicklinx: D4SYWS00 Mfr#: HB30C3A1CST
Type: Docking station
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 4
Form Factor: External
£41.22 ex VAT
£49.46 inc VAT
Add three USB Type-A ports and one USB Type-C port to your USB-C equipped computer, using this mountable USB 3.0 (5Gbps) hub. This USB-C hub turns your laptop or desktop USB Type-C port into two standard USB-A ports, one USB-A fast-charge port, and one USB-C port. You can also extend the range of your USB devices by using this hub as a mid-point repeater.
The 4-port hub is designed for easy port access when the hub is mounted or sitting on your desk. The hub ports are spaced with enough room between them to easily plug or unplug your USB devices, without having to disconnect other devices from neighboring ports.
With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or simply avoid the hassle of swapping connected devices on your port-limited laptop. The hub lets you extend the life of your current USB 3.0 devices while also taking advantage of newer USB-C devices.
It's perfect for IT professionals or anyone who needs to plug and unplug their devices regularly.
This hub is the perfect accessory for a laptop or desktop workstation, with a rugged metal housing that can withstand the wear and tear of daily use.
With the included wall-mount bracket, you can attach the hub to a surface such as a desktop or a wall, to best suit your needs.
With the available fast-charge port, the hub helps to ensure that your tablet or smartphone are charged and ready to use when you need them. You can also sync and access your device while it's charging. The USB-A charge port supports USB Battery Charging Specification 1.2 and delivers up to 2.4 amps of power, so you can charge your mobile device faster than traditional USB ports allow.
  • Connect more devices quickly and easily
    The 4-port hub is designed for easy port access when the hub is mounted or sitting on your desk. The hub ports are spaced with enough room between them to easily plug or unplug your USB devices, without having to disconnect other devices from neighboring ports. With extra USB 3.2 Gen 1 ports, you can increase productivity and connect more devices to your computer, or simply avoid the hassle of swapping connected devices on your port-limited laptop. The hub lets you extend the life of your current USB 3.2 Gen 1 devices while also taking advantage of newer USB-C devices. It's perfect for IT professionals or anyone who needs to plug and unplug their devices regularly.
  • Enjoy mounted or desktop convenience
    This hub is the perfect accessory for a laptop or desktop workstation, with a rugged metal housing that can withstand the wear and tear of daily use. With the included wall-mount bracket, you can attach the hub to a surface such as a desktop or a wall, to best suit your needs.
  • Charge-and-sync your mobile devices
    With the available fast-charge port, the hub helps to ensure that your tablet or smartphone are charged and ready to use when you need them. You can also sync and access your device while it's charging. The USB-A charge port supports USB Battery Charging Specification 1.2 and delivers up to 2.4 amps of power, so you can charge your mobile device faster than traditional USB ports allow. The HB30C3A1CST is backed by a 2-year StarTech.com warranty and free lifetime technical support.
StarTech.com 4 Port USB C Hub - USB Type-C to 1x USB-C/3x USB-A - Commercial Metal USB 3.0 Hub - SuperSpeed 5Gbps USB 3.1/3.2 Gen 1 - Self Powered - BC1.2 Fast Charge - Mountable/Rugged (HB30C3A1CST) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x USB-C
USB 1.1, USB 2.0, USB 3.0
AC 120/230 V
6 cm x 10 cm x 2.6 cm
300 g
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
P/N: SVA12M2NEUA, SVA12M5NA
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Status Indicators
Port status, power
3 x USB 3.0 Type A 2.4A charging port , 1 x USB 3.1 Gen 1 Type C , 1 x USB 3.0 Type B
External power adapter
AC 120/230 V
Rubber feet, mounting brackets, mounting screws
1 x USB-C to USB-B cable
FCC, RoHS, USB Battery Charging Specification Rev. 1.2
6 cm
10 cm
2.6 cm
300 g
5 °C
35 °C
20 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
50 °C
D4SY StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £19.33
D4SY StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £20.75
D4SY StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £30.59
D4SY StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.29
D4SY StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £45.59
D4SY StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £27.64
D4SY StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.59
D4SY StarTech.com 2m 6ft USB 3.0 C to B Cable In Stock £13.23
D4SY StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
D4SY StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
D4SY StarTech.com 1m USB A to C Cable - USB 3.0 In Stock £8.23
D4SY StarTech.com 7 Port USB C Hub - C to C & A In Stock £66.79
D4SY StarTech.com 7 Port USB-C Hub - C to C & A In Stock £70.78
D4SY StarTech.com 4-Port USB-C Hub - USB 3.1 In Stock £34.22
D4SY StarTech.com 4-Port USB 3.0 Hub with On/Off In Stock £24.24
D4SY StarTech.com 4-Port Industrial USB 2.0 Hub In Stock £145.20
D4SY StarTech.com 7-Port Industrial USB 2.0 Hub In Stock £182.49
D4SY StarTech.com 4-Port USB-C Hub, 100W PD In Stock £38.06
D4SY StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £31.91
Speed: 5Gbps
Ports: 4
