Connect USB 3.0 USB-A devices to a USB hub or to your computer. This USB 3.1 Gen 1 (5Gbps) cable, also known as a USB 3.0 cable, lets you connect your USB-A devices as needed throughout your workspace. With a connection distance of up to 3 meters (10 feet), you can organize your PC and USB hub, or other USB-A devices, to match your configuration needs.
Plus, this high-quality cable features Shielded Twisted Pair (STP) construction, which helps to prevent electro-magnetic interference and ensure reliable data communication.
- StarTech.com 3m 10 ft USB 3.0 Cable - A to A - M/M - Long USB 3.0 Cable - USB 3.1 Gen 1 (5 Gbps) (USB3SAA3MBK) - USB cable - USB Type A to USB Type A - 3 m
- USB cable
- Technology
- Shielded twisted pair (STP)
- Molded, strain relief, 5 Gbps data rate
- Length
- 3 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: HB30C1A1CPD, HB30C3A1CFBW, HB30C3A1CST, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, HB30C5A2CSC, HB30C5A2CST, SV231DPU34K, SV431DPU3A2, USB32VGAEH, USB3EXT6INBK
- USB cable
- Technology
- Length
- 3 m
- Black
- Connector
- USB 3.0
- Designed For
StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £12.03 |
StarTech.com 3m USB 3.0 Active Extension Cable - M/F | In Stock | £71.01 |
StarTech.com 5m USB 3.0 Active Extension Cable - M/F | In Stock | £82.51 |
StarTech.com 10m USB 3.0 Active Extension Cable - M/F | In Stock | £116.91 |
StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £7.20 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.67 |
StarTech.com 5 ft Black Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £11.76 |
StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £7.57 |
StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.41 |
