StarTech.com 4 Port USB Adaptor  PCI Express USB 3.1 Gen 2 Controller Card - 3xA + 1xC
Quicklinx: DZ71WS00 Mfr#: PEXUS313AC2V
Add three USB-A ports and one USB-C port, via two host controllers, through a standard PCI Express slot. This USB 3.1 PCIe card lets you add three USB Type-A ports and one USB Type-C port to your computer, through a PCI Express slot. It makes it easy to upgrade your PC to the faster speed of USB 3.1 (10Gbps) so that you can access newer peripherals at twice the speed of traditional USB 3.0 (5Gbps) cards.
When multiple devices are connected, traditional single-bus USB cards share the maximum bandwidth between all ports. By employing two host controller chipsets, shared across two ports rather than four, this 4-port PCIe to USB 3.1 card dedicates up to 10Gbps for each set of two USB ports. It reduces performance bottlenecks and doubles your total available bandwidth to 20Gbps.
With higher data throughput support, the card is ideal for external hard drives, hard drive enclosures, and large external storage devices. It lets you access multiple devices simultaneously for read and write access.
The 4-port USB 3.1controller card adds dual independent channels to your computer and shares 10Gbps of bandwidth between two USB ports.
Each set of two ports shares a combined bandwidth of 10Gbps. If a single device is accessing the channel, the card will provide data transfer rates of up to 10Gbps to the device. If two devices are accessing the channel simultaneously, the 10Gbps of bandwidth will be shared between both devices.
  • Faster USB performance
    When multiple devices are connected, traditional single-bus USB cards share the maximum bandwidth between all ports. By employing two host controller chipsets, shared across two ports rather than four, this 4-port PCIe to USB 3.2 card dedicates up to 10Gbps for each set of two USB ports. It reduces performance bottlenecks and doubles your total available bandwidth to 20Gbps. With higher data throughput support, the card is ideal for external hard drives, hard drive enclosures, and large external storage devices. It lets you access multiple devices simultaneously for read and write access.
  • Shared bandwidth
    The 4-port USB 3.2 controller card adds dual independent channels to your computer and shares 10Gbps of bandwidth between two USB ports. Each set of two ports shares a combined bandwidth of 10Gbps. If a single device is accessing the channel, the card will provide data transfer rates of up to 10Gbps to the device. If two devices are accessing the channel simultaneously, the 10Gbps of bandwidth will be shared between both devices. The PEXUS313AC2V is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 4 Port USB 3.1 PCIe Card - 1x USB C & 2x A - 2 10Gbps Channels (PEXUS313AC2V) - USB adapter - PCIe 3.0 x4 - USB 3.1 Gen 2 x 3 + USB-C 3.1 Gen 2 x 1
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express 3.0 x4
PCI Specification Revision
PCIe 3.0
Ports
USB, USB 2.0, USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2
Apple macOS 10.13, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
P/N: HB31C2A1CGS, HB31C3A1CS, HB31C4AS, USB3C2ESAT3
USB adapter
Plug-in card
PCI Express 3.0 x4
PCIe 3.0
Ports
Wired
USB, USB 2.0, SuperSpeed USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
Built-in SATA power connector, built-in LP4 Molex power connector
3 x USB 3.1 Gen 2 - 9 pin USB Type A (external) , 1 x USB 3.1 Gen 2 - 24 pin USB-C (external)
DZ71 StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
DZ71 StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £80.54
DZ71 StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £11.00
DZ71 StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
DZ71 StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £62.29
DZ71 StarTech.com 7 Port PCIe USB 3.0 Card In Stock £56.73
DZ71 StarTech.com 4 Port PCIe USB 3.0 Card In Stock £27.19
DZ71 StarTech.com 4 Port PCIe USB 3.0 Card In Stock £23.79
DZ71 StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.43
DZ71 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
DZ71 StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.01
DZ71 StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.81
