Add four USB 3.0 ports to your computer, plus fast-charge your mobile device. Here's a must-have accessory for any mobile device user. This compact USB 3.0 hub lets you connect an additional four USB devices to your computer, plus, you can easily fast-charge your mobile device using the hub's dedicated charge port (DCP).
With a 2.4 amp dedicated charge port, the hub makes it fast and easy to charge your smartphone, tablet, and other USB-charged devices, including Android, Apple, and Samsung devices.
The charge and data ports work simultaneously, so you can conveniently fast-charge your mobile device while continuing to use your other USB 3.0 peripherals. The dedicated charge port stays on even if the host computer is turned off, in sleep mode, or disconnected entirely.
Boost your system capabilities by adding four USB 3.0 ports, and enjoy fast data transfer speeds up to 5Gbps. The USB 3.0 (also known as USB 3.1 Gen 1) hub works with your high-bandwidth devices such as external hard drives, high-resolution webcams, flash drives, video cameras, and more.
The 4-port USB 3.0 hub features a small footprint that takes up little space on your desktop. And with ample space between each USB 3.0 port, it's easy to plug and unplug the devices you use the most.
Setup is easy, with no driver installation required, and, for added flexibility the hub is USB-powered or self-powered using the included power adapter.
Note: The included power adapter is required to power the dedicated charge port.
Fast-charge your iPad, iPhone, and other mobile devices
With a 2.4 amp dedicated charge port, the hub makes it fast and easy to charge your smartphone, tablet, and other USB-charged devices, including Android, Apple, and Samsung devices. The charge and data ports work simultaneously, so you can conveniently fast-charge your mobile device while continuing to use your other USB 3.0 peripherals. The dedicated charge port stays on even if the host computer is turned off, in sleep mode, or disconnected entirely. -
Expand the connectivity of your computer
Boost your system capabilities by adding four USB 3.0 ports, and enjoy fast data transfer speeds up to 5Gbps. The USB 3.0 hub works with your high-bandwidth devices such as external hard drives, high-resolution webcams, flash drives, video cameras, and more. -
Designed for easy use
The 4-port USB 3.0 hub features a small footprint that takes up little space on your desktop. And with ample space between each USB 3.0 port, it's easy to plug and unplug the devices you use the most. Setup is easy, with no driver installation required, and, for added flexibility the hub is USB-powered or self-powered using the included power adapter.
- StarTech.com 4-Port USB 3.0 Hub plus Dedicated Charging Port - 1 x 2.4A Port - Desktop USB Hub and Fast-Charging Station (ST53004U1C) - USB peripheral sharing switch - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- Plastic housing
- USB 1.1, USB 2.0, USB 3.0
- Power
- AC 120/230 V 2 A
- 6.1 cm x 10.6 cm x 2.5 cm
- 100 g
- Black
- Localisation
- Australia, North America, United Kingdom, Europe
- 2-year warranty
- Designed For
- P/N: SDMSDRWU3AC, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Plastic housing
- Processor
- X VIA VL812
- Status Indicators
- Port status
- 4 x USB 3.0 Type A
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Electric Current Required
- 2 A
- 24 Watt
- Black
- Cables Included
- 1 x SuperSpeed USB cable
- FCC, RoHS, WEEE, RCM
- Localisation
- 6.1 cm
- 10.6 cm
- 2.5 cm
- 100 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Designed For
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power | In Stock | £23.76 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels | In Stock | £48.60 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels | In Stock | £81.81 |
StarTech.com 10-Pt USB 3.0 Hub w/ Charging | In Stock | £64.21 |
StarTech.com 7-Pt USB 3.0 Hub + Charge Pts | In Stock | £58.79 |
StarTech.com 4 Port Portable USB 3.0 Hub | In Stock | £24.39 |
StarTech.com 4PT USB 3.0 Hub - Charge Port | In Stock | £31.05 |
