StarTech.com 7-Pt USB 3.0 Hub + Charge Pts
Quicklinx: BT5RWS00 Mfr#: ST93007U2C
Type: USB Hub
Interface: USB 3.1 Type C
Speed: 5Gbps
Ports: 7
Form Factor: External
£54.82 ex VAT
£65.78 inc VAT
Add seven USB 3.0 ports and two USB fast-charge ports to your computer. This 7-port USB 3.0 hub functions as a traditional data hub for your computer, as well as a two-port charging station for your mobile devices. Now you can easily add seven USB 3.0 ports and two 2.4A fast-charging ports to your MacBook, laptop or desktop. It's the perfect addition to any home, office or hot-desk environment.
Two 2.4 amp dedicated charging ports (DCP) provide fast charging for your smartphones, tablets and other USB-charged devices. The charging ports are located on the top of the hub for quick and easy access.
The charging and data ports work simultaneously, so you can conveniently fast-charge your mobile devices while still using your USB 3.0 devices. The hub will also charge devices even if your computer is disconnected, in sleep mode, or turned off.
Increase your productivity by adding seven USB 3.0 (also known as USB 3.1 Gen 1) ports to your workstation. With support for data transfer rates up to 5Gbps, the hub is perfect for connecting high-bandwidth devices such as external hard drives, printers, scanners, high-resolution webcams, video cameras, and more.
This USB 3.0 hub is the ideal accessory for your laptop or desktop computer. Its small footprint takes up little space on your desktop, and there's plenty of room between each USB port, making it easy to plug and unplug the devices you use most often. Plus, you can set the hub up in seconds, with no driver installation required.
  • Fast-charge your Android, iPad and iPhone
    Two 2.4 amp dedicated charging ports (DCP) provide fast charging for your smartphones, tablets and other USB-charged devices. The charging ports are located on the top of the hub for quick and easy access. The charging and data ports work simultaneously, so you can conveniently fast-charge your mobile devices while still using your USB 3.0 devices. The hub will also charge devices even if your computer is disconnected, in sleep mode, or turned off.
  • Expand the connectivity of your computer
    Increase your productivity by adding seven USB 3.0 ports to your workstation. With support for data transfer rates up to 5Gbps, the hub is perfect for connecting high-bandwidth devices such as external hard drives, printers, scanners, high-resolution webcams, video cameras, and more.
  • Designed for easy use
StarTech.com 9 Port USB 3.0 Hub - 7 x USB-A, 2 x USB-A Fast Charge Ports - Multi Port Powered USB Charging Station (ST93007U2C) - USB peripheral sharing switch - 7 ports
Subtype
USB
Ports
7 x SuperSpeed USB 3.0
Plastic housing
USB 1.1, USB 2.0, USB 3.0
AC 120/230 V 2 A
6 cm x 20 cm x 2.3 cm
120 g
Australia, North America, United Kingdom, Europe
P/N: USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Enclosure Type
Desktop
Subtype
USB
Ports
Plastic housing
X VIA VL812
Status Indicators
Port status
7 x USB 3.0 Type A
External power adapter
AC 120/230 V
Electric Current Required
2 A
48 Watt
1 x SuperSpeed USB cable
FCC, RoHS, WEEE, RCM
6 cm
20 cm
2.3 cm
120 g
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
BT5R StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £20.74
BT5R StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £22.94
BT5R StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels In Stock £51.61
BT5R StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £25.34
BT5R StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £61.67
BT5R StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £43.24
BT5R StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £54.82
BT5R StarTech.com 4 Port Portable USB 3.0 Hub In Stock £23.79
BT5R StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £30.29
Type: USB Hub
Speed: 5Gbps
Ports: 7
