Add three USB Type-A ports and one USB Type-C port to your computer, using this mountable USB 3.0 (5Gbps) hub. This 4-port USB 3.0 hub turns your laptop or desktop USB-A port into two standard USB-A ports, one USB-A fast-charge port and one USB-C port. You can also extend the range of your USB devices by using this hub as a mid-point repeater.
The 4-port hub is designed for easy port access, when the hub is mounted or sitting on your desk. The hub ports are spaced with enough room between them to easily plug or unplug your USB devices, without having to disconnect other devices from neighboring ports.
With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or simply avoid the hassle of swapping connected devices on your port-limited laptop. The USB-C port is ideal for connecting new USB-C devices, like an external USB-C drive, to a traditional USB-A port on your computer.
It's perfect for IT professionals or anyone who needs to plug and unplug their devices regularly.
This hub is perfect the perfect accessory for a laptop or desktop workstation, with a rugged metal housing that can withstand the wear and tear of daily use.
With the included wall-mount bracket, you can attach the hub to a surface such as a desktop or wall, to better suit your needs.
With the available fast-charge port, the hub helps to ensure that your tablet or smartphone are charged and ready to use when you need them. You can also sync and access your device while it is charging. The USB-A charge port supports USB Battery Charging Specification 1.2 and delivers up to 2.4 amps of power, so you can charge your mobile device faster than traditional USB ports allow.
Connect more devices quickly and easily
The 4-port hub is designed for easy port access, when the hub is mounted or sitting on your desk. The hub ports are spaced with enough room between them to easily plug or unplug your USB devices, without having to disconnect other devices from neighboring ports. With extra USB 3.2 Gen 1 ports, you can increase productivity and connect more devices to your computer, or simply avoid the hassle of swapping connected devices on your port-limited laptop. The USB-C port is ideal for connecting new USB-C devices, like an external USB-C drive, to a traditional USB-A port on your computer. It's perfect for IT professionals or anyone who needs to plug and unplug their devices regularly. -
Enjoy mounted or desktop convenience
This hub is perfect the perfect accessory for a laptop or desktop workstation, with a rugged metal housing that can withstand the wear and tear of daily use. With the included wall-mount bracket, you can attach the hub to a surface such as a desktop or wall, to better suit your needs. -
Charge-and-sync your mobile devices
With the available fast-charge port, the hub helps to ensure that your tablet or smartphone are charged and ready to use when you need them. You can also sync and access your device while it is charging. The USB-A charge port supports USB Battery Charging Specification 1.2 and delivers up to 2.4 amps of power, so you can charge your mobile device faster than traditional USB ports allow. The HB30A3A1CST is backed by a 2-year StarTech.com warranty and free lifetime technical support.
- StarTech.com 4 Port USB 3.0 Hub, USB Type-A to 1x USB-C & 3x USB-A, Commercial Metal USB Hub, SuperSpeed 5Gbps USB 3.1/3.2 Gen 1, Self Powered, BC 1.2 Fast Charge/Sync, Mountable/Rugged - Windows/macOS/Linux (HB30A3A1CST) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 3 x SuperSpeed USB 3.0 + 1 x USB-C
- USB 1.1, USB 2.0, USB 3.0
- Power
- AC 120/230 V
- 6 cm x 10 cm x 2.6 cm
- 200 g
- Black
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Status Indicators
- Port status, power
- 3 x USB 3.0 Type A 2.4A charging port , 1 x USB 3.1 Gen 1 Type C , 1 x USB 3.0 Type B
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Included Accessories
- Rubber feet, mounting brackets, mounting screws
- Cables Included
- 1 x USB-A to USB-B cable - 1 m
- FCC, RoHS, USB Battery Charging Specification Rev. 1.2
- Localisation
- 6 cm
- 10 cm
- 2.6 cm
- 200 g
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 50 °C
- Designed For
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black | In Stock | £21.38 |
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable | In Stock | £23.49 |
StarTech.com USB 3.0 IDE / SATA Enclosure | In Stock | £25.51 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.72 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £33.96 |
StarTech.com 4 Port Portable USB 3.0 Hub | In Stock | £25.01 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £21.00 |
StarTech.com 2m 6ft USB 3.0 C to B Cable | In Stock | £15.04 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
StarTech.com 1m USB A to C Cable - USB 3.0 | In Stock | £11.29 |
StarTech.com 4 Port USB 3.0 Hub A to C & A | In Stock | £45.41 |
StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C | In Stock | £29.98 |
