StarTech.com 4 Port USB 3.0 Hub - USB-C Hub
Quicklinx: BMPSWS00 Mfr#: HB30C3A1CFB
Type: USB Hub
Interface: USB 3.1 Type C, SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 4
Form Factor: External
20 In Stock
£29.84 ex VAT
£35.80 inc VAT
Turn a USB Type-C port on your laptop into three USB Type-A ports (5Gbps) and one USB Type-C port. The 4-port USB 3.0 hub lets you connect both USB-C and USB-A peripherals to your laptop or Chromebook, through a single USB Type-C or Thunderbolt 3 port.
The hub is ideal for virtually all USB-C equipped laptops, such as the Dell Latitude 11 5000 2-in-1, and the Dell XPS 12.
This USB 3.1 Gen 1 hub lets you expand your USB connection options using the USB-C port on your computer. It offers one USB-C and three USB-A ports, letting you connect traditional USB devices now, while still being able to connect the growing number of USB Type-C devices in the future.
The integrated, easy-to-use USB Type-C connector is small and reversible, which makes for easier insertions. You can connect the plug with either side facing up, which means less risk of damaging your ports, and less frustration.
With a compact and lightweight design, the USB-powered hub is tailored for mobility. It easily tucks into your carrying case and expands your connectivity when traveling.
Plus, this versatile USB hub takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
Avoid the nuisance and cost of purchasing new peripherals by using this USB 3.0 hub with your current USB 3.0 and 2.0 devices. The bus-powered hub installs in seconds with no additional drivers or software required, and it's compatible with virtually all operating systems.
StarTech.com 4-Port USB 3.0 Hub - Powered USB 3.1 Gen 1 Hub - USB-C to 1x USB-C and 3x USB-A Adapter - USB-C Port Expander (HB30C3A1CFB) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 3.0, USB 3.1
4 cm x 7.5 cm x 1.3 cm
P/N: 2SD4FCRU3C, CFASTRWU3C, FCREADU3C, MST30C2DPPD, S251BU31C3CB, SDMSDRWU3AC, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
USB 3.0, USB 3.1
3 x USB 3.0 Type A , 1 x USB 3.0 Type C
FCC, RoHS
4 cm
7.5 cm
1.3 cm
60 °C
0 - 90%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
BMPS StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £18.86
BMPS StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - White In Stock £19.16
BMPS StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £20.25
BMPS StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £7.73
BMPS StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £8.90
BMPS StarTech.com USB-C to Gigabit Adapter In Stock £22.86
BMPS StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £29.84
BMPS StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £8.63
BMPS StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £9.60
BMPS StarTech.com 7 Port Compact USB 3.0 Hub In Stock £43.64
BMPS StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £42.51
BMPS StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £25.61
BMPS StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £27.39
BMPS StarTech.com 4 Port USB C Hub with PD 2.0 In Stock £34.11
BMPS StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 In Stock £45.82
BMPS StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £29.07
BMPS StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £39.13
BMPS StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £36.34
BMPS StarTech.com 4 Port USB C Hub - C to C & A In Stock £26.12
BMPS StarTech.com 4 Port USB 3.0 Hub A to C & A In Stock £41.13
BMPS StarTech.com 7 Port USB C Hub - C to C & A In Stock £65.16
BMPS StarTech.com 7 Port USB-C Hub - C to C & A In Stock £67.97
BMPS StarTech.com 4-Port USB-C Hub - USB 3.1 In Stock £33.92
BMPS StarTech.com 4-Port USB 3.0 Hub with On/Off In Stock £23.64
BMPS StarTech.com 4 Port USB 3.0 Hub USB-C to 4x USB-A In Stock £30.53
BMPS StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C In Stock £24.21
BMPS StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £42.74
BMPS StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £25.05
BMPS StarTech.com 4-Port USB-C Hub, 100W PD In Stock £37.13
BMPS StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £31.13
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 4
