StarTech.com 4 Port SuperSpeed USB 3.0 PCI Express Card with UASP - SATA Power
Quicklinx: 7RX8WS00 Mfr#: PEXUSB3S4
  • Windows 8 (32/64 bits)
Add 4 USB 3.0 ports to your desktop computer through a PCI Express expansion slot. The PEXUSB3S4 4-Port PCI Express SuperSpeed USB 3.0 Card (with SATA Power) adds 3 external USB 3.0 ports and an internal USB 3.0 port to any PCI Express-enabled computer system. With SuperSpeed USB 3.0, you can reach data transfer speeds up to 5 Gbps, while still being backward compatible with existing USB 2.0 devices at 480Mbps.
Enhanced with UASP support (USB Attached SCSI Protocol), this USB 3.0 controller performs up to 70% faster than conventional USB 3.0 when paired with a UASP supported enclosure (Note: UASP requires a compatible operating system). Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP technology optimizes transfers by allowing multiple commands to be processed simultaneously, significantly increasing transfer speeds for less wait time on data transfers.
With a built-in SATA power connector, each USB port can provide up to 900mA of power to USB 3.0 devices (500mA for USB 2.0) by connecting to your computer power supply. For added versatility, the controller card is equipped with a standard profile bracket and includes a low-profile/half-height bracket for installation in small form-factor computers.
UASP is supported in Windows 8, Server 2012 and Linux kernel 2.6.3 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources.
Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
StarTech.com 4 Port SuperSpeed USB 3.0 PCI Express Card with SATA Power - USB adapter - PCIe - 4 ports
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
2.2 cm x 9 cm x 7.7 cm
60 g
Ports Qty
4 ports
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
P/N: S2510BU33PW, S251SMU33EP, S3510BMU33, S3510SMU33, S3520BU33ER, S352BU313R, S3540BU33E, SATDOCK2REU3, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U33, SDOCKU33BV, SDOCKU33EBV, UNI251BMU33, USB31000NDS, USB31000SW, USB3HDCAP, USB3S2ESATA3, USB3S2SAT3CB
USB adapter - 4 ports
Plug-in card
PCI Express x1
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
3 x USB 3.0 - 9 pin USB Type A (external) , 1 x USB 3.0 (internal)
Compatible Slots
1 x PCI Express
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
2.2 cm
9 cm
7.7 cm
60 g
5 °C
50 °C
20 - 80%
P/N: 35BAYUSB3S4, S2510BU33PW, S251SMU33EP, S3510BMU33, S3510SMU33, S3520BU33ER, S352BU313R, S3540BU33E, SATDOCK2REU3, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U33, SDOCKU33BV, SDOCKU33EBV, UNI251BMU33, USB31000NDS, USB31000S, USB31000SW, USB3HDCAP, USB3S2ESATA3, USB3S2SAT3CB
7RX8 StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £43.31
7RX8 StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £103.00
