StarTech.com 4-Port Serial PCIe Card
Quicklinx: HKKYWS00 Mfr#: PS74ADF-SERIAL-CARD
Wired / Wireless: [N/A]
Protocol: [N/A]
Form Factor: [N/A]
Compatibility: [N/A]
Type: [N/A]
16 In Stock
£138.69 ex VAT
£166.42 inc VAT
Add serial communication support to a desktop computer or Small Form Factor (SFF) system, using this 4-Port Serial PCI Express Card. The four DB9 ports can be independently configured to support RS-232, RS-422, and 2/4-wire RS-485 standards, for communication with compliant serial peripheral devices.
  • Per-Port Serial Configuration
    This PCIe Serial Card is equipped with on-board DIP switches, enabling each DB9 serial port to operate in RS-232, RS-422, and/or RS-485 mode(s). The card features LED indicators per port, providing real-time monitoring of port activity.
  • Configurable External SATA Power
    The PCI Express Serial Adapter Card features three power modes that are configurable via on-board jumpers, including 12V (1.5A per port), 5V (1.5A per port), or no power (RI), over pin 9.
  • Legacy Connectivity
    This serial card enables the continued use of legacy serial devices, preventing down time and avoiding costly upgrades. The 4-Port PCIe Serial Card is an ideal system upgrade for a wide range of applications (e.g., point-of-sale terminals, PLCs, factory control and automation, scientific sensors, medical equipment, scanners, and oscilloscopes)
StarTech.com 4-Port Serial PCIe Card, Quad-Port PCI Express to RS232/RS422/RS485 (DB9) Serial Card, Low-Profile Bracket Incl., 16C1050 UART, TAA-Compliant, For Windows/Linux, TAA Compliant - Level-4 ESD Protection (PS74ADF-SERIAL-CARD) - serial adapter - PCIe - RS-232 x 4 - TAA Compliant
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 2.0
Ports
RS-232 x 4
10.9 cm 1.6 cm
Length
12.1 cm
60 g
RS-232, RS-422, RS-485
Data Transfer Rate
921.6 Kbps
16C550 UART, 16C450 UART, 16C950 UART
Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Microsoft Windows 7 / 8 / 8.1 / 10 / 11
TAA Compliant
Serial adapter
PCI Express x1
PCIe 2.0
Ports
RS-232 x 4
Wired
Data Transfer Rate
921.6 Kbps
Status Indicators
Status, data
Software flow control, hardware flow control, 256-byte FIFO, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), 15KV ESD Protector (HBM)
4 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI
4 x low-profile brackets
3 x serial panel (internal) - 30 cm
RoHS
TAA Compliant
10.9 cm
1.6 cm
Length
12.1 cm
60 g
Shipping Width
14.4 cm
Shipping Depth
20.7 cm
Shipping Height
3.8 cm
Shipping Weight
273.2 g
70 °C
20 - 80% RH
HKKY StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.42
HKKY StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.02
HKKY StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.16
HKKY StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.57
HKKY StarTech.com 2-Port Serial PCIe Card In Stock £64.74
Protocol: [N/A]
Form Factor: [N/A]
Type: [N/A]
