Add serial communication support to a desktop computer or Small Form Factor (SFF) system, using this 2-Port Serial PCI Express Card. The two DB9 ports can be independently configured to support RS-232, RS-422, and 2/4-wire RS-485 standards, for communication with compliant serial peripheral devices.
Per-Port Serial Configuration
This PCIe Serial Card is equipped with on-board DIP switches, enabling each DB9 serial port to operate in RS-232, RS-422, and/or RS-485 mode(s). The card features LED indicators per port, providing real-time monitoring of port activity. -
Configurable External SATA Power
The PCI Express Serial Adapter Card features three power modes that are configurable via on-board jumpers, including 12V (1.5A per port), 5V (1.5A per port), or no power (RI), over pin 9. -
Legacy Connectivity
This serial card enables the continued use of legacy serial devices, preventing down time and avoiding costly upgrades. The 2-Port PCIe Serial Card is an ideal system upgrade for a wide range of applications (e.g., point-of-sale terminals, PLCs, factory control and automation, scientific sensors, medical equipment, scanners, and oscilloscopes).
- StarTech.com 2-Port Serial PCIe Card, Dual-Port PCI Express to RS232/RS422/RS485 (DB9) Serial Card, Low-Profile Brackets Incl., 16C1050 UART, TAA-Compliant, Windows/Linux, TAA Compliant - Level-4 ESD Protection (2S232422485-PC-CARD) - serial adapter - PCIe - RS-232 x 2 - TAA Compliant
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 2.0
- Ports
- RS-232 x 2
- 10.2 cm 1.6 cm
- Length
- 10.5 cm
- 57 g
- Data Link Protocol
- RS-232, RS-422, RS-485
- Data Transfer Rate
- 921.6 Kbps
- 16C550 UART, 16C450 UART, 16C950 UART
- Black
- System Requirements
- Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Linux 2.6.13 or later
- TAA Compliant
- 2-year warranty
- Serial adapter
- Form Factor
- PCI Express x1
- PCIe 2.0
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- 921.6 Kbps
- Status Indicators
- Status, data
- Software flow control, hardware flow control, 256-byte FIFO, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), 15KV ESD Protector (HBM)
- 2 x RS-232 - 9 pin D-Sub (DB-9) - male (external)
- Included Accessories
- 2 x low-profile brackets
- Cables Included
- 1 x serial panel (internal) - 30 cm
- RoHS
- Black
- TAA Compliant
- OS Required
- 10.2 cm
- 1.6 cm
- Length
- 10.5 cm
- 57 g
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 140 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 20 - 80% RH
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.95 |
StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £5.01 |
StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £5.62 |
StarTech.com 4-Port Serial PCIe Card | In Stock | £138.69 |
