This 4-port SATA III (6Gbps) controller enables you to add four SATA 6Gbps Hard Drives (HDDs) or Solid State Drives (SSDs) to your computer system or server via an available PCIe x4 card slot. The card supports SATA III and PCI-Express 3.0 Specifications.
ASM1164 to Deliver 4-Port SATA 6Gbps Performance
Featuring the ASM1164 controller, this SATA card enables the connection of four high-performance SATA 6Gbps drives with a combined total throughput of up to 16Gbps. The SATA drives are connected via four individual SATA ports located on the card (SATA cables sold separately). -
Wide Compatibility
The controller card is widely supported across all popular operating system platforms including Windows (7, 8, 10), macOS (10.10 and above) and Linux (2.6.32 and above). The card also supports port multiplier, giving you the ability to connect multiple drives to a single SATA port (additional hardware required, sold separately). To further improve motherboard compatibility the card does not have a built-in RAID controller, but fully supports the use of software RAID. Plus, with support for PCIe 3.0 and SATA III Specifications this card ensures backward compatibility with previous generations (SATA I/II, PCIe 1/2) at lower performance. -
Hassle-Free Installation
The SATA controller card features plug-and-play installation and can be installed in a full-profile or low-profile computer systems with the full-profile bracket preinstalled, and an interchangeable low-profile (half-height) bracket included. The card also supports storage software data management systems such as Storage Spaces (Microsoft) , RAID Assistant (MacOS) and mdraid/mdadm (Linux), for hassle-free setup, partitioning and software RAID array building. 4P6G-PCIE-SATA-CARD is backed by a StarTech.com 2-year warranty and free lifetime 24/5 North American based, multi-lingual support.
 - StarTech.com SATA PCIe Card, 4 Port PCIe SATA Expansion card, 6Gbps SATA Card, Low/Full Profile, SATA Stacked Connectors, ASM1164 Non-Raid SATA Controller Card - PCI Express to SATA Converter - storage controller - SATA 6Gb/s - PCIe 3.0 x2
 - Storage controller - plug-in card - low profile
- Bus Type
 - PCIe 3.0 x2
 - Red
- Interface
 - SATA 6Gb/s
- Data Transfer Rate
 - 6 Gbit/s
- Supported Devices
 - Hard drive, solid state drive
- Max Storage Devices Qty
 - 4
- System Requirements
 - Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.10 or later, Linux 2.6.32 or later
 - 5.6 cm x 7 cm x 1.6 cm
 - 75 g
 - 2-year warranty
- Host Bus
 - PCIe 3.0 x2
 - Red
Storage Controller
- Interface
 - SATA 6Gb/s
 - 6 Gbit/s
- Supported Devices
 - 4
- Processor
 - ASMedia ASM1164
 - 4 x SATA 6Gb/s - SATA (internal)
- Included Accessories
 - Low-profile bracket
 - S.M.A.R.T. support, TRIM support, 4Kn drive compatible, bootable, ATAPI support
 - RoHS, WEEE, RCM
- OS Required
 - Limited warranty - 2 years
 - 5.6 cm
 - 7 cm
 - 1.6 cm
 - 75 g
- Shipping Width
 - 14.2 cm
- Shipping Depth
 - 17 cm
- Shipping Height
 - 3 cm
- Shipping Weight
 - 115 g
 - 0 °C
 - 85 °C
 - 20 - 80% RH
                        StarTech.com 24" Serial ATA Cable | In Stock | £5.16 |
                        StarTech.com 18in SATA Serial ATA Cable | In Stock | £2.51 |
                        StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.70 |
                        StarTech.com 12in Latching SATA Cable | In Stock | £5.50 |
                        StarTech.com 18in Latching SATA Cable | In Stock | £3.89 |
                        StarTech.com 24in Latching SATA Cable | In Stock | £6.76 |
                        StarTech.com 6in SATA Serial ATA Cable | In Stock | £3.55 |
                        StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.46 |
                        StarTech.com 8 Port SATA 6Gbps PCIe Card | In Stock | £77.07 |
                        StarTech.com 6-Port SATA PCIe Card - 6Gbps | In Stock | £51.38 |
                        StarTech.com 10-Port SATA PCIe Card - 6Gbps | In Stock | £81.20 |
