StarTech.com 18in SATA Serial ATA Cable
Quicklinx: 3ZLLWS00 Mfr#: SATA18
Length: 45.8cm
Type: ATA
More than 50 In Stock
£4.34 ex VAT
£5.20 inc VAT
This high quality SATA cable is designed for connecting SATA drives even in tight spaces. The SATA18 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 18in SATA Serial ATA Cable - 18in SATA Cable - 18 SATA Cable - 18in Serial ata Cable - SATA cable - 45.8 cm
SATA cable
Length
45.8 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 25SAT35HDD, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET25SAT, IDE2SAT25, PATA2SATA3, PEXSAT32, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SAT32MSATPEX, ST521PMINT, USB3SSATAIDE
Storage Cable Type
SATA cable
Length
45.8 cm
Connector
P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 25SAT35HDD, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET25SAT, HSB220SAT25B, IDE2SAT25, PATA2SATA3, PEXSAT32, PEXSATA22I, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SAT32MSATPEX, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
3ZLL StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
Length: 45.8cm
Type: ATA
