StarTech.com 4 Port RS232 PCI Serial Card Adapter with Power Output
Quicklinx: 84NTWS00 Mfr#: PCI4S954PW
Add 4 RS232 serial ports with 5V or 12V selectable power output to your computer, through a PCI slot. The PCI4S954PW 4-Port PCI Serial Card (with power output) turns a PCI slot into 4 RS232 (DB9) serial connections and enables compatible devices to draw power from the serial ports.
Suitable for many RS232-powered serial applications, this PCI serial card offers a selectable 5V or 12V power option, capable of power output using pin 1, 4, 8 or 9, which enables you to configure the card to suit the requirements of your powered RS232 devices.
A flexible solution for adding serial ports to full-sized, or small form factor systems, the 4-port serial card includes both low and full profile brackets while the included breakout cable helps to avoid cluttered connections.
StarTech.com 4 Port RS232 PCI Serial Card Adapter with Power Output - serial adapter - PCI - RS-232 x 4
Serial adapter
Plug-in card
Interface (Bus) Type
PCI
PCI Specification Revision
PCI 3.0
Ports
RS-232 x 4
1.9 cm x 5.7 cm x 12 cm
95 g
RS-232
Data Transfer Rate
460.8 Kbps
OXUPCI954
Microsoft Windows Server 2003, Linux 2.4.x, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7, Windows 10 (32/64 bits)
Serial adapter
Plug-in card
PCI
PCI 3.0
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
460.8 Kbps
Processor / Memory
OXUPCI954
4 x RS-232 - 9 pin D-Sub (DB-9) , 1 - 4 PIN internal power
Compatible Slots
1 x PCI
Low-profile bracket
1.9 cm
5.7 cm
12 cm
95 g
50 °C
5 - 85% (non-condensing)
84NT StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
84NT StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £155.21
