StarTech.com 4 Port Portable USB 3.0 Hub
Quicklinx: BV5XWS00 Mfr#: ST43004UA
Type: USB Hub
Interface: USB 3.1 Type C
Speed: 5Gbps
Ports: 4
Form Factor: External
£23.79 ex VAT
£28.54 inc VAT
Add four USB 3.0 (5Gbps) ports to your MacBook, using this silver, Apple style hub with an extended-length cable. This 4-port portable USB 3.0 hub is tailored to match the stylish design of your MacBook, or laptop with a similar matte silver finish. It features a sleek, silver sandblasted housing that looks great next to your Apple laptop, and because the hub is designed with a solid-aluminum casing, it provides the lightweight durability that's ideal for either travel or desktop usage.
It also integrates a lengthier, 27 cm (10.5 in) cable, so you have the flexibility to place the hub and your devices exactly where you need them.
This high-quality, Apple style USB hub gives you an easy way to expand your MacBook connectivity. It provides four USB 3.0 (also known as USB 3.1 Gen 1) hub ports in a compact housing. Its silver sandblast finish provides a unique and stylish look when compared to traditional hubs. Now your USB hub can look as trendy and contemporary as your MacBook or Ultrabook, or your laptop that features a similar finish or shade.
The hub's built-in USB cable has sufficient length to reach your laptop's USB 3.0 port, regardless of where the port is located. Plus, the extended-length cable provides you with more desk placement options.
If you're looking for portability, then this hub can help. Its compact and lightweight design makes it ideal for travel. Plus, with a built-in USB cable, you can tuck the versatile hub neatly into your travel bag, and avoid the nuisance of carrying around a separate power adapter.
With a rugged aluminum housing, the hub offers dependable protection, so it's perfect for back-and-forth trips from home to office. Plus, the compact USB hub takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
This bus-powered hub is plug-and-play and hot-swap compatible, so you can install it quickly, with no additional drivers or software required. You can also avoid the nuisance and cost of purchasing new devices by using the USB 3.0 hub with your current USB 2.0 and 1.x devices.
  • Compact Design
    The hub’s compact design makes it easy to carry in a laptop bag or pocket, allowing for on-the-go connectivity to multiple USB devices.
  • Reliable Connectivity
    With compliance to USB 3.0 standards, the hub provides reliable connectivity for high-speed data transfer, ensuring efficient performance across various devices.
  • Efficient Temperature Range
    This hub operates efficiently in a wide temperature range from 0°C to 40°C, making it suitable for different environments and conditions.
  • High Environmental Compliance
    The product adheres to important environmental standards such as FCC, RoHS, and WEEE, highlighting its commitment to sustainability.
StarTech.com 4 Port Portable USB 3.0 Hub with Built-in Cable - Aluminum and Compact USB Hub (ST43004UA) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB 1.1, USB 2.0, USB 3.0
11.2 cm x 3.6 cm x 1.8 cm
82 g
White, silver
Hub - 4 ports
Subtype
USB
Ports
Status Indicators
4 x USB 3.0 Type A
White, silver
1 x USB power cable - 26.8 cm
Plug and Play, FCC, RoHS, WEEE
11.2 cm
3.6 cm
1.8 cm
82 g
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
BV5X StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.73
BV5X StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.44
BV5X StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £15.00
BV5X StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £19.16
BV5X StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £20.25
BV5X StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £46.54
BV5X StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.23
BV5X StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £60.78
BV5X StarTech.com 4 Port PCIe USB 3.0 Card In Stock £23.56
BV5X StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £7.96
BV5X StarTech.com 3Pt Portable USB 3.0 Hub + GbE In Stock £33.70
BV5X StarTech.com 7 Port Compact USB 3.0 Hub In Stock £43.64
BV5X StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £43.24
BV5X StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £54.82
BV5X StarTech.com 4 Port Portable USB 3.0 Hub In Stock £23.79
BV5X StarTech.com 4 Port Portable USB 2.0 Hub In Stock £8.39
BV5X StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £29.07
BV5X StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £39.13
BV5X StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £30.29
BV5X StarTech.com 4Port USB C Hub C to A USB 2.0 In Stock £20.83
BV5X StarTech.com 4 Port USB 3.0 Hub A to C & A In Stock £41.13
BV5X StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £42.74
BV5X StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £25.05
Type: USB Hub
Speed: 5Gbps
Ports: 4
