StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F
Quicklinx: 8FJ0WS00 Mfr#: USB3SEXT1MBK
Length: 1m
Colours:
More than 50 In Stock
£6.71 ex VAT
£8.05 inc VAT
Extend your SuperSpeed USB 3.0 cable by up to an additional meter. The USB3SEXT1MBK Black SuperSpeed USB 3.0 extension cable (1m, A-A), offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, this USB 3.0 male to female cable extends a USB 3.0 cable connection by up to 1 meter and delivers the full USB 3.0 bandwidth of 5Gbps, supporting maximum throughput between compatible devices when used with a USB 3.0 host and device.
The USB 3.0 extension cord features high quality Shielded Twisted Pair (STP) construction, helping to prevent electromagnetic interference and ensuring reliable data communication.
  • Reliable connectivity
    This USB extension cable features a male to female design with 9-pin USB Type-A connectors, ensuring a secure link between devices while supporting a variety of USB applications.
  • Enhanced performance
    Utilizing SFTP technology, the cable minimizes interference and maximizes performance, delivering consistent data transfer speeds.
  • Robust construction
    Constructed with nickel-plated connectors, this USB extension cable offers durability and long-lasting performance, making it suitable for frequent use across various environments.
  • Cross-compatibility
    The cable is compliant with USB / USB 2.0 / USB 3.0 standards, allowing compatibility with a wide range of devices and making it an essential addition to your tech accessories.
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - Male to Female USB 3 Extension Cable Cord 1 m (USB3SEXT1MBK) - USB extension cable - USB Type A to USB Type A - 1 m
USB extension cable
Shielded foiled twisted pair (SFTP)
Length
1 m
Connector
9 pin USB Type A - male
Connector (Second End)
9 pin USB Type A - female
P/N: 2SD4FCRU3, BNDDKT30CAHV, CFASTRWU3, FCREADMICRO3, MSDREADU3CA, ST3300G3UA, ST3300GU3B, ST43004UA, ST4300MINI, ST7300U3M, SV211DPUA, SV211DPUA4K, SV211HDUA4K, USB2001EXT2, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB31GEHD, USB31GEVG, USB3SAA3MBK, USB3SMDOCKHV, USBA2DPGB
USB extension cable
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1 m
Connector
USB / USB 2.0 / USB 3.0, RoHS
P/N: 2SD4FCRU3, BNDDKT30CAHV, CFASTRWU3, FCREADMICRO3, MSDREADU3CA, ST3300G3UA, ST3300GU3B, ST43004UA, ST4300MINI, ST7300U3M, SV1631DUSBUK, SV211DPUA, SV211DPUA4K, SV211HDUA4K, SVUSB2N1_6, USB2001EXT2, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB31GEHD, USB31GEVG, USB3SAA3MBK, USB3SMDOCKHV, USBA2DPGB
8FJ0 StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.71
8FJ0 StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.71
8FJ0 StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.99
8FJ0 StarTech.com 6in USB 3.0 Extension Cable In Stock £5.41
8FJ0 StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.29
Length: 1m
