Add four USB 3.0 ports to your laptop or Ultrabook using this slim, portable hub with an extended-length cable. This 4-Port Portable USB 3.0 Hub with Built-in Cable turns a single USB 3.0 port into four, letting you connect more of your devices to your computer.
The hub features a built-in, 25 cm (10 in) cable that is longer than what most traditional hubs offer. The extended-length cable gives you the flexibility to place the hub and your devices exactly where you want them, and it ensures the hub can connect to your laptop or tablet regardless of where the laptop's USB 3.0 port is located.
This portable USB 3.0 hub is great for adding extra ports to your laptop, tablet, Microsoft Surface Pro 4, Surface Book, and other Microsoft Surface products.
With an integrated cable you have more flexibility to place the hub on your desk as desired. Plus, the hub is USB-powered for easy transport when you travel.
This USB hub offers a block-style design with ports placed across the top surface of the hub. With upright port access your connected devices (for example, flash drives and mouse and keyboard wireless receivers) take up less desk space.
Alternatively, you can lay the hub on its side for easy cable connections to devices like external hard drivers or printers.
With its compact design, you can easily position the USB 3.0 (also known as USB 3.1 Gen 1) hub on your desk or workspace to make your USB devices more accessible. There's also ample space between the USB 3.0 ports, so it's easy to plug and unplug the devices you use the most.
The USB 3.0 hub is natively supported in virtually all operating systems, which makes for an easy setup with no driver installation required. And because it's backward compatible, you can connect both new and legacy USB devices (for example USB 2.0 peripherals).
Expand the connectivity of your laptop when you travel
This portable USB 3.0 hub is great for adding extra ports to your laptop, tablet and other products. With an integrated cable you have more flexibility to place the hub on your desk as desired. Plus, the hub is USB-powered for easy transport when you travel. -
Upright port-configuration saves desk space
This USB hub offers a block-style design with ports placed across the top surface of the hub. With upright port access your connected devices (for example, flash drives and mouse and keyboard wireless receivers) take up less desk space. -
Designed for easy use
- StarTech.com 4-Port USB 3.0 Hub with Built-in Cable - SuperSpeed Laptop USB Hub - Portable USB Splitter - Mini USB Hub (ST4300PBU3) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB powered
- USB 1.1, USB 2.0, USB 3.0
- 3 cm x 13.7 cm x 2.2 cm
- 80 g
- Black
- System Requirements
- Microsoft Windows 2000, Apple MacOS X 10.0 or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- 2-year warranty
- Designed For
- P/N: FCREADMICRO3, MSDREADU3CA
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB powered
- Status Indicators
- Power
- 4 x USB 3.0 Type A , 1 x USB 3.0 Type A
- Black
- Cables Included
- 1 x USB cable - 25.4 cm
- FCC, RoHS
- OS Required
- 3 cm
- 13.7 cm
- 2.2 cm
- 80 g
- Limited warranty - 2 years
- -5 °C
- 45 °C
- 20 - 80%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 75 °C
- Designed For
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £38.96 |
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black | In Stock | £20.24 |
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - White | In Stock | £20.24 |
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable | In Stock | £20.75 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £39.78 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £67.46 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £30.59 |
StarTech.com 4 Port Portable USB 3.0 Hub | In Stock | £24.39 |
StarTech.com 4 Port USB C Hub with PD 2.0 | In Stock | £34.96 |
StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 | In Stock | £49.12 |
StarTech.com 4 Port USB 3.0 Hub with USB C | In Stock | £29.79 |
StarTech.com 4 Port USB 3.0 Hub with USB C | In Stock | £41.30 |
StarTech.com 4 Port USB C Hub - C to C & A | In Stock | £27.58 |
StarTech.com 4PT USB 3.0 Hub - Charge Port | In Stock | £31.05 |
StarTech.com 4 Port USB 3.0 Hub A to C & A | In Stock | £44.11 |
StarTech.com 7 Port USB-C Hub - C to C & A | In Stock | £70.78 |
StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable | In Stock | £45.14 |
StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable | In Stock | £26.45 |
