Add four USB 3.0 ports - three external ports and one internal port - to your computer. Here's a cost-effective solution for adding USB 3.0 connectivity to your computer. This 4-port PCIe USB 3.0 card gives you three external ports and one internal port, for the ultimate connection flexibility.
With three external USB 3.0 ports you can connect more devices to your computer. The card provides easy access to commonly-used peripherals such as your tablet and external hard drive. It also features an internal USB port that lets you connect a device such as a flash drive inside your computer case, providing added security and convenience.
USB 3.0 gives you fast access to your files with data transfer rates up to 5 Gbps. Plus it's backward compatible with USB 2.0 and 1.x devices, which eliminates the cost and aggravation of upgrading your existing devices.
Setup is a breeze with native operating system support. The USB 3.0 adapter card automatically installs in Windows.
For convenient installation, this PCI Express USB 3.0 card features a dual-profile design that can be installed in almost any type of computer. It comes equipped with a standard profile bracket and also includes a low-profile bracket for installation in small form-factor/half-height systems.
This high-performance USB 3.0 card is enhanced with UASP support, which can perform ~70% faster read speed and ~40% faster write speed over traditional USB 3.0, when paired with.
- StarTech.com 4 Port PCI Express USB 3.0 Card - 3 External and 1 Internal - Native OS Support in Windows 8 and 7 - Standard and Low-Profile (PEXUSB3S42) - USB adapter - PCIe 2.0 - USB 3.0 x 4
- USB adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 2.0 x1
- Ports
- USB 3.0 x 4
- 1.9 cm x 8.7 cm x 12 cm
- 59 g
- Data Link Protocol
- USB, USB 2.0, USB 3.0
- Data Transfer Rate
- 5 Gbps
- Processor
- VL805 VL805
- USB 1.1, USB 2.0, USB 3.0
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Linux 2.6.31 or later, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
- 2-year warranty
- Designed For
- P/N: CFASTRWU3, ST1030USBM, ST43004UA, ST4300MINI, TB31PCIEX16
- USB adapter
- Form Factor
- Ports
- USB 3.0 x 4
- Connectivity Technology
- Wired
- USB, USB 2.0, SuperSpeed USB 3.0
- 5 Gbps
- Built-in SATA power connector, USB Attached SCSI Protocol (UASP)
Processor / Memory
- Processor
- VL805 VL805
- 3 x USB 3.0 - 9 pin USB Type A (external) , 1 x USB 3.0 - 9 pin USB Type A (internal) , 1 - 15 pin Serial ATA power (internal)
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 1.9 cm
- 8.7 cm
- 12 cm
- 59 g
- Limited warranty - 2 years
- 5 °C
- 50 °C
- 20 - 80%
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £2.96 |
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £24.13 |
StarTech.com 5m USB 3.0 Active Extension Cable - M/F | In Stock | £58.51 |
StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black | In Stock | £62.49 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels | In Stock | £61.44 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels | In Stock | £73.15 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £38.18 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £36.09 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £48.04 |
StarTech.com 7 Port PCIe USB 3.0 Card | In Stock | £49.47 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £25.36 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £23.95 |
