StarTech.com 1-Port USB 3.2 Gen 2x2 PCIe Card - USB-C SuperSpeed 20Gbps PCI Express 3.0 x4
Quicklinx: G59YWS00 Mfr#: PEXUSB321C
Type: USB adapter
Compatibility: PC
Interface: PCI Express 3.0 x4
£40.64 ex VAT
£48.76 inc VAT
USB 3.2 Gen 2x2 (20 Gbps) PCI-Express 3.0 PCIe x4 Slot USB Type-C. This PCIe USB 3.2 Gen 2x2 controller card installs into an available PCI-Express x4 slot in your computer and enables you to upgrade your current system by adding a USB-C (20Gbps) port.
Add a 20 Gbps USB Type-C Port to Your Desktop Computer
The controller card enables you to connect USB-C Gen 2x2 (20 Gbps) devices to your desktop computer. The USB-C port is ideal for connecting USB devices such as external hard drives and solid state drives or charging and syncing your mobile devices. The USB-C port provides up to 15W (5V/3A) of power and is backward compatible with USB 3.2 Gen 2 (10 Gbps) and USB 3.2 Gen 1 (5 Gbps) devices.
Note: USB 3.2 Gen 2 (10 Gbps) is also know as USB 3.1 Gen 2 (10 Gbps), and USB 3.2 Gen 1 (5 Gbps) is also know as USB 3.0 and USB 3.1 (5 Gbps).
SuperSpeed USB 3.2 Gen 2x2 (20 Gbps) Performance
The USB 3.2 Gen 2x2 card features an ASMedia ASM3242 host controller that utilizes x4 lanes of the PCIe 3.0 bus, making the card capable of speeds up to 20Gbps and enabling fast access to high-performance devices like NVMe drives and SSDs. The controller card supports Multiple INs to reduce bandwidth loss when multiple devices are connected through a USB Hub (Note: The USB hub must also support this feature). The card also supports UASP for improved performance with storage devices.
Wide Installation Compatibility
This add-on card includes both full-profile and low-profile installation brackets ensuring you can install it into either a full or low-profile PCIe 3.0 x4 slot (backward compatible w/PCIe 2.0). For wide platform support the card is compatible with Windows, Linux and macOS. For hassle-free installation the drivers install automatically on computers running Windows 8 or higher. Works w/USB 3.1/3.0/2.0 devices
PEXUSB321C is backed by a StarTech.com 2-year warranty and free lifetime 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
  • Add a 20 Gbps USB Type-C Port to Your Desktop Computer
    The controller card enables you to connect USB-C Gen 2x2 (20 Gbps) devices to your desktop computer. The USB-C port is ideal for connecting USB devices such as external hard drives and solid state drives or charging and syncing your mobile devices. The USB-C port provides up to 15W (5V/3A) of power and is backward compatible with USB 3.2 Gen 2 (10 Gbps) and USB 3.2 Gen 1 (5 Gbps) devices. Note: USB 3.2 Gen 2 (10 Gbps) is also know as USB 3.2 Gen 2 (10 Gbps), and USB 3.2 Gen 1 (5 Gbps) is also know as USB 3.2 Gen 1 and USB 3.2 (5 Gbps).
  • SuperSpeed USB 3.2 Gen 2x2 (20 Gbps) Performance
  • Wide Installation Compatibility
    This add-on card includes both full-profile and low-profile installation brackets ensuring you can install it into either a full or low-profile PCIe 3.0 x4 slot (backward compatible w/PCIe 2.0). For wide platform support the card is compatible with Windows, Linux and macOS. For hassle-free installation the drivers install automatically on computers running Windows 8 or higher. Works w/USB 3.2/3.0/2.0 devices PEXUSB321C is backed by a StarTech.com 2-year warranty and free lifetime 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
StarTech.com USB 3.2 Gen 2x2 PCIe Card - USB-C 20Gbps PCI Express 3.0 x4 Controller - USB Type-C Add-On PCIe Expansion Card -Windows/Linux - USB adapter - PCIe 3.0 x4 - USB-C 3.2 Gen 2x2 x 1
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 3.0 x4
Ports
8 cm x 5.1 cm x 2.2 cm
37 g
USB 3.2 Gen 2x2
Data Transfer Rate
20 Gbps
ASMedia ASM3242
USB 2.0, USB 3.0, USB 3.1, USB 3.1 Gen 2, xHCI 1.1, USB 3.2 Gen 2, USB 3.2 Gen 1, USB 3.2 Gen 2x2
Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Windows 8 / 8.1 / 10 / 11, Microsoft Windows Server 2019, Apple macOS 10.13 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Linux 3.5 or later, Linux LTS versions only
USB adapter
PCI Express 3.0 x4
Ports
Wired
USB 3.2 Gen 2x2
Data Transfer Rate
20 Gbps
Processor / Memory
ASMedia ASM3242
1 x USB 3.2 Gen 2x2 - 24 pin USB-C
Low-profile bracket
MTBF
3,126,209 hours
FCC, RoHS, UASP (USB Attached SCSI Protocol)
8 cm
5.1 cm
2.2 cm
37 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
101 g
85 °C
15 - 90%
G59Y StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
G59Y StarTech.com 1m Thunderbolt 3 20Gbps Cable In Stock £33.89
G59Y StarTech.com 0.5m Thunderbolt 3 Cable In Stock £29.30
G59Y StarTech.com 0.5m USB 3.1 C - Micro B Cable In Stock £9.59
G59Y StarTech.com 4-Port USB-C Hub - USB 3.1 In Stock £34.22
G59Y StarTech.com 0.8m / 2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps In Stock £32.51
G59Y StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C In Stock £32.28
G59Y StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps In Stock £55.62
G59Y StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps In Stock £47.36
G59Y StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter In Stock £63.26
G59Y StarTech.com 4-Port USBC Hub - 10Gbps In Stock £47.00
G59Y StarTech.com 4-Port USB C Hub USB 3.1 Gen 2 (10Gbps) 3x USB-A & 1x USB-C In Stock £59.54
G59Y StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 In Stock £29.33
G59Y StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C In Stock £42.62
G59Y StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance In Stock £64.63
G59Y StarTech.com USB C Multiport Adapter - 4K HDMI/PD/USB/GbE- Mini Dock In Stock £57.12
Type: USB adapter
Compatibility: PC
