100W Power Delivery Pass Through 1X USB-C Port 2x USB-A Port 10" Attached Cable. This USB-C multiport adapter with HDMI turns your MacBook Pro, Dell XPS, or other USB-C laptops into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, a USB Type-C port (data/power), two USB 3.2 Gen 2 Type-A (10Gbps) ports, and a Gigabit Ethernet port, all through one connection to your laptop's USB-C or Thunderbolt 3 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 10-inch (25 cm) host cable for an extended reach to offer more set up flexibility.
Enhance Productivity
The portable docking station connects your laptop to a 4K HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
Connect Your Devices
The USB-C to USB 3.2 Gen 2 hub gives you one USB-C port and two USB-A ports to connect your latest and legacy USB devices.
Charge Your Laptop and Peripherals
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
Reliable Network Connectivity
The Gigabit Ethernet port ensures reliable wired network access.
The DKT31CHPDL is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
The portable docking station connects your laptop to a 4K HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor. -
The USB-C to USB 3.2 Gen 2 hub gives you one USB-C port and two USB-A ports to connect your latest and legacy USB devices. -
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). -
The Gigabit Ethernet port ensures reliable wired network access. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
- StarTech.com USB C Multiport Adapter, 10Gbps USB Type-C Mini Dock with 4K 30Hz HDMI, 100W Power Delivery Passthrough, 3-Port USB Hub, GbE, Portable USB 3.1/3.2 Gen 2 Laptop Dock, 10" Cable - Portable Travel Dock - docking station - USB-C 3.2 Gen 2 / Thunderbolt 3 - HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- HDMI
- 3.66 cm x 4.68 cm x 1.6 cm
- 94.5 g
- Grey
- Networking
- Gigabit Ethernet
- 3-year warranty
- Designed For
- P/N: PEXUSB321C
- Product Type
- Docking station
- 3.66 cm
- 4.68 cm
- 1.6 cm
- 94.5 g
- Enclosure Colour
- Grey
Video
- Max Resolution Details
- 4096 x 2160 - 30 Hz
- Data Link Protocol
- USB 3.1, USB 3.2 Gen 2
- 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x USB 3.2 Gen 2 - 9 pin USB Type A , 1 x USB 3.2 Gen 2 with Battery Charging 1.2 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C 3.2 Gen 2 with Power Delivery (100 W)
- Cables Included
- 1 x Thunderbolt 3 / USB-C cable - integrated - 25 cm
- LED indicator
- FCC, RoHS, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 3.0
- OS Required
- Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Android, Apple MacOS X 10.6.2, Google Chrome OS, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Microsoft Windows Server 2016, Apple macOS Sierra 10.12, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple iPadOS, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Microsoft Windows 7 / 8 / 10 / 11, Apple macOS Ventura 13.0
- Limited warranty - 3 years
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 94.7 g
- 0 °C
- 70 °C
- Designed For
- P/N: PEXUSB321C
StarTech.com USB C Multiport Adapter | In Stock | £64.31 |
StarTech.com 3-Port USB-C Hub w/Gb Ethernet | In Stock | £30.87 |
