Quicklinx: BPZLWS00 Mfr#: ST1000SPEX43
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Ethernet, Fast Ethernet
Form Factor: Plug-in card
Compatibility: PC, Unix
Type: Network adapter
15 In Stock
£118.88 ex VAT
£142.65 inc VAT
Add four Gigabit Ethernet ports to a client, server or workstation through one PCI Express slot. Now you can add four separate Gigabit network ports to your client, server or workstation through just one PCI Express slot, to provide connectivity to multiple networks without draining your budget.
This 4-port network card delivers powerful connectivity for your business, corporate or government office environment, with support for high-performance, 4-channel networking and a maximum throughput of up to 1000 Mbps in each direction (2000 Mbps total). The network adapter card features the Realtek RTL8111G chipset, which is designed to deliver the performance and enhanced capabilities you need for reliable network connections to your server or computer.
This versatile quad-port network card is ideal for many business applications requiring upgrades to servers or workstations, adding feature-rich Gigabit networking with four independent ports. Compatible with a broad range of operating systems, this cost-effective PCIe Gigabit NIC is suitable for many SMB and Enterprise applications such as virtualized environments that require multiple NICs.
StarTech.com 4 Port Gigabit NIC PCIe Network Card - Quad Port Adapter (ST1000SPEX43) - network adapter - PCIe - Gigabit Ethernet x 4
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express
Ports
1.8 cm x 13.8 cm x 12 cm
100 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Realtek Semiconductor RTL8111G
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
Yellow
Microsoft Windows Server 2003, Microsoft Windows Server 2012, Microsoft Windows XP/ 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Network adapter
Plug-in card
PCI Express
Ports
Wired
Cabling Type
Status Indicators
Link/activity
Flow control, WOL, auto-uplink (auto MDI/MDI-X), full duplex mode, Jumbo Frames support, priority encoding, tagged VLAN
Processor / Memory
4 x 1000Base-T - RJ-45
FCC, RoHS
Yellow
1.8 cm
13.8 cm
12 cm
100 g
55 °C
5 - 95%
BPZL StarTech.com 4-Port Gigabit NIC - PCIe In Stock £151.83
Protocol: Ethernet
Protocol: Fast Ethernet
Compatibility: PC
Compatibility: Unix
