Add two RS232, and two RS422/485 serial ports to your PC through a PCI-Express expansion slot. The PEX4S232485 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 lets you add two RS232, and two RS422/485 serial ports to your PC through a PCI-Express expansion slot.
This PCI express serial card is a single card solution that is compatible with nearly any serial communication protocol, supporting RS-232, RS-422, RS-485 2-wire or RS-485 4-wire operating modes.
A flexible solution for adding serial ports to full-sized, or small form factor systems, the 4-port serial card includes both low and full profile brackets while the included breakout cable helps to avoid cluttered connections.
Secure connectivity
This card features wired technology, ensuring stable and secure connections for various devices requiring serial communication. The combination of RS-232 and RS-422/485 interfaces expands applicability across multiple devices. -
Robust operating range
Designed to function optimally between 0°C and 100°C, this card handles a wide range of environmental conditions, making it dependable for diverse settings without compromising performance. -
Standard compliance
The StarTech.com 4 Port PCI Express PCIe Serial Combo Card adheres to FCC and RoHS standards, ensuring it meets safety regulations and environmental guidelines, making it a trustworthy solution for professionals.
 - StarTech.com 4 Port PCI Express PCIe Serial Combo Card - serial adapter - PCIe - 4 ports
 - Serial adapter
- Form Factor
 - Plug-in card
- Interface (Bus) Type
 - PCI Express x1
 - 2 cm x 7 cm x 12.5 cm
 - 67.4 g
- Ports Qty
 - 4 ports
- Data Link Protocol
 - RS-232, RS-422, RS-485
- System Requirements
 - Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10
 - Limited lifetime warranty
- Designed For
 - P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
 - Serial adapter - 4 ports
- Form Factor
 - Plug-in card
 - PCI Express x1
- Connectivity Technology
 - Wired
 - 2 x RS-232 - 9 pin D-Sub (DB-9) (on cable) , 2 x RS-422/485 - 9 pin D-Sub (DB-9) (on cable)
- Compatible Slots
 - 1 x PCI Express x1
- Included Accessories
 - Low-profile bracket
 - FCC, RoHS
- OS Required
 - 2 cm
 - 7 cm
 - 12.5 cm
 - 67.4 g
 - Limited warranty - lifetime
 - 0 °C
 - 100 °C
 - 20 - 80%
- Designed For
                        StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention | In Stock | £78.53 |
                        StarTech.com 2 Port PCI Express RS232 Serial Adapter Card | In Stock | £35.73 |
                        StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD | In Stock | £151.41 |
                        StarTech.com 1-Prt PCI Express Serial Card | In Stock | £36.07 |
                        StarTech.com PCIe Dual Serial Port Card | In Stock | £41.75 |
                        StarTech.com 2-Port Serial PCIe Card | In Stock | £63.15 |
                        StarTech.com 4-Port Serial PCIe Card | In Stock | £135.32 |
