Add two RS232, and two RS422/485 serial ports to your PC through a PCI-Express expansion slot. The PEX4S232485 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 lets you add two RS232, and two RS422/485 serial ports to your PC through a PCI-Express expansion slot.
This PCI express serial card is a single card solution that is compatible with nearly any serial communication protocol, supporting RS-232, RS-422, RS-485 2-wire or RS-485 4-wire operating modes.
A flexible solution for adding serial ports to full-sized, or small form factor systems, the 4-port serial card includes both low and full profile brackets while the included breakout cable helps to avoid cluttered connections.
- StarTech.com 4 Port PCI Express PCIe Serial Combo Card - serial adapter - PCIe - 4 ports
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- 2 cm x 7 cm x 12.5 cm
- 67.4 g
- Ports Qty
- 4 ports
- Data Link Protocol
- RS-232, RS-422, RS-485
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10
- Limited lifetime warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
- Serial adapter - 4 ports
- Form Factor
- Plug-in card
- PCI Express x1
- Connectivity Technology
- Wired
- 2 x RS-232 - 9 pin D-Sub (DB-9) (on cable) , 2 x RS-422/485 - 9 pin D-Sub (DB-9) (on cable)
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- OS Required
- 2 cm
- 7 cm
- 12.5 cm
- 67.4 g
- Limited warranty - lifetime
- 0 °C
- 100 °C
- 20 - 80%
- Designed For
StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention | In Stock | £82.78 |
StarTech.com 2 Port PCI Express RS232 Serial Adapter Card | In Stock | £37.07 |
StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD | In Stock | £159.61 |
StarTech.com 1-Prt PCI Express Serial Card | In Stock | £38.02 |
StarTech.com PCIe Dual Serial Port Card | In Stock | £44.02 |
StarTech.com 2-Port Serial PCIe Card | In Stock | £66.56 |
StarTech.com 4-Port Serial PCIe Card | In Stock | £142.62 |
