StarTech.com 4-Port Industrial USB 2.0 Hub
Quicklinx: DXDRWS00 Mfr#: HB20A4AME
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Form Factor: DIN rail mountable
£146.36 ex VAT
£175.63 inc VAT
This TAA compliant 4-port industrial USB hub provides four USB 2.0 ports to connect your devices. The USB 2.0 hub can be surface or DIN rail mounted, providing convenient USB connectivity in a work area, server room, or industrial environment.
The USB hub, with its rugged metal housing and IP30 protection rating, is built to meet the harsh demands of industrial environments. The 15kV ESD Protection (Level 4) reduces the risk of disruption caused by high static industrial environments, which can lead to costly service calls and downtime. To ensure maximum performance, the industrial USB hub provides an extended operating temperature range (-40°C - 85°C).
The hub's wide-range 7-48V DC terminal block input gives you the flexibility to power the hub as required, based on your own power input capabilities. For low-power applications, the hub can be operated through the host USB bus power.
For easy port access, the 4-port industrial USB hub can be surface or wall-mounted, and includes an optional DIN rail mount kit. The plug-and-play ports connect easily to printers, cameras, sensors and other devices. Each port also features its own Transaction Translator (TT), to assist with load balancing and ensure each port can operate at peak performance.
StarTech.com 4 Port USB 2.0 Hub, Metal Industrial USB-A Hub (4x USB-A) with ESD & Surge Protection, Extended Operating Temp -40 to 185°F, Din Rail/Wall/Desk Mountable, USB Expander Hub - Windows/macOS/Linux (HB20A4AME) - hub - 4 ports - TAA Compliant
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
Surge protection, 15KV ESD Protector
USB 2.0
DC 7 - 24 V
9.5 cm x 5.5 cm x 3.2 cm
350 g
TAA Compliant
P/N: ITB20D3250
Hub - 4 ports
Enclosure Type
DIN rail mountable
Subtype
USB
Ports
4 x USB 2.0
USB 2.0
X Genesys Logic GL852GT
Status Indicators
4 x USB 2.0 Type A , 1 x USB 2.0 Type B
External power adapter
DC 7 - 24 V
DIN-rail mounting kit
1 x USB-A to USB-B cable - 1.8 m
Plug and Play, FCC, RoHS, WEEE
TAA Compliant
9.5 cm
5.5 cm
3.2 cm
350 g
-40 °C
85 °C
5 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
P/N: ITB20D3250
DXDR StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £62.14
DXDR StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £82.96
DXDR StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £28.32
DXDR StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £98.93
DXDR StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £111.14
DXDR StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £133.39
DXDR StarTech.com 4-Port Industrial USB 2.0 Hub In Stock £146.36
DXDR StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £40.79
DXDR StarTech.com Industrial USB 3.0 Hub In Stock £306.30
DXDR StarTech.com Industrial USB 5Gbps Hub In Stock £314.99
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
