Brand
StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio
Quicklinx: 7B7KWS00 Mfr#: ST124HDMI2
Hurry, only 1 left in stock!
£101.00 ex VAT
£121.20 inc VAT
Split an HDMI audio and video signal to four displays simultaneously. The ST124HDMI2 4 Port High Speed HDMI Video Splitter with Audio lets you share a single HDMI source with up to 4 HDMI or DVI-D enabled displays/receivers, without sacrificing image or sound quality. Mounting brackets are included for a tidy, professional installation.
Supporting true HD video resolutions up to 1080p, this HDMI splitter allows you to situate your HDMI-capable displays up to 15ft (5m) away from the splitter. This versatile HDMI splitter features 3.5mm audio input and output connections giving you the option of sending your accompanying audio signal through the HDMI cable or through a separate 3.5mm stereo audio channel.
A perfect addition to virtually any application requiring the high quality video delivered by HDMI devices, the ST124HDMI2 video splitter is easy to install and provides flawless, distortion-free digital video.
StarTech.com HDMI Splitter 1 In 4 Out - 1080p - 4 Port -Mounting Brackets - 1.3 Audio - HDMI Multi Port - HDMI Audio Splitter (ST124HDMI2) - video splitter - 4 ports
Video splitter - 4 ports
Subtype
HDMI
Ports
4 x HDMI + 4 x audio
AC 120/230 V
13.5 cm x 22 cm x 4.4 cm
1.6 kg
P/N: SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
HDMI
Ports
Max Resolution
1920 x 1200 / 1080p
HDTV support
4 x HDMI output , 4 x audio output mini-jack , 1 x HDMI input , 1 x audio input mini-jack
External power adapter
AC 120/230 V
13.5 cm
22 cm
4.4 cm
1.6 kg
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
7B7K StarTech.com 6 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.07
7B7K StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £8.80
7B7K StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £23.35
7B7K StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.90
7B7K StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.47
7B7K StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.63
7B7K StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £16.93
7B7K StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.91
7B7K StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter In Stock £58.75
7B7K StarTech.com 4K HDMI 4-Port Video Splitter In Stock £72.73
7B7K StarTech.com DC Power Adapter - 12V, 2A In Stock £13.92
7B7K StarTech.com DC Power Adapter - 12V, 5A In Stock £45.71
7B7K StarTech.com 8-Port 4K 60Hz HDMI Splitter In Stock £131.54
7B7K StarTech.com HDMI Splitter - 2 Port - 4K 60Hz In Stock £37.81
7B7K StarTech.com HDMI Splitter - 4 Port - 4K 60Hz In Stock £53.39
Stock Status: In stock
