Product
StarTech.com 4-Port Gigabit NIC - PCIe
Quicklinx: BJWWWS00 Mfr#: ST4000SPEXI
Wired / Wireless: Wired
Protocol: Gigabit Ethernet
Compatibility: PC, Unix
Type: Network adapter
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Hurry, only 2 left in stock!
£186.30 ex VAT
£223.56 inc VAT
Add four Gigabit Ethernet ports to a client, server or workstation through a single PCI Express slot. Here's a dependable and cost-effective way to add four high-performance Gigabit Ethernet ports to your server or desktop computer, through one PCI Express slot.
This Gigabit Ethernet network card features the Intel I350-AM4 chipset, designed to deliver the power, performance and enhanced capabilities you need for reliable network connections to your server or computer. The Intel chip provides a number of advanced driver options including IEEE 802.3ad link aggregation / teaming support, which enables you to add additional bandwidth to your system.
Compliant with IEEE 802.3/u/ab standards, the network card provides full support for high-performance, four-channel networking and maximum throughput up to 1000Mbps in each direction (2000 Mbps total) - up to ten times faster than 10/100 Ethernet.
The quad-port Gigabit network card makes it easy to access multiple networks. It offers a cost-effective solution for IT professionals in government, educational, corporate, health care, or business environments where access to multiple networks from numerous workstations is needed. The server adapter card gives you four redundant, independent Gigabit Ethernet ports and it supports advanced features such as Jumbo Frames and VLAN tagging.
Compatible with a broad range of operating systems, this versatile PCIe Gigabit NIC is suitable for many business and enterprise applications - including virtualized environments with multiple operating systems, requiring multiple shared or dedicated NICs. The 4-port Gigabit network card is equipped with Intel Virtualization Technology for Connectivity (Intel VT-c) which reduces system latency and improves networking throughput. Four dedicated ports allow you to maximize your virtualized server's networking efficiency and create a more agile data center.
With a dual-profile design, the PCI Express network card installs easily into a wide range of computer/server chassis, regardless of form factor. The card is equipped with a full-sized bracket, and includes a low-profile/half-height installation bracket that you can use as needed.
StarTech.com 4-Port Gigabit Ethernet Network Card - PCI Express, Intel I350 NIC - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x4
1.8 cm x 13.2 cm x 12 cm
95 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
GigE
Data Transfer Rate
1 Gbps
Performance
Forwarding performance (full duplex): 2 Gbps
Jumbo frame size: 9000
I350-AM4 - Intel
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
2 years warranty
Network adapter
PCI Express x4
Wired
Cabling Type
GigE
Data Transfer Rate
1 Gbps
Performance
Status Indicators
Port status, link/activity
Full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support
Processor / Memory
I350-AM4 - Intel
4 x network - RJ-45
Low-profile bracket
FCC, RoHS
4.4 Watt
1.8 cm
13.2 cm
12 cm
95 g
5 °C
50 °C
20 - 80%
BJWW StarTech.com 25 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £7.36
BJWW StarTech.com 10 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 10ft Patch Cord In Stock £3.21
BJWW StarTech.com 25 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 25ft Patch Cord In Stock £4.17
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 150 - 300
