Robust construction
The KVM switch is built with a durable steel housing that ensures long-lasting performance and protection from physical damage. -
High-performance video support
With support for a maximum resolution of 3684 x 2160 at 60 Hz, this switch delivers stunning visuals for an enhanced viewing experience. -
User-friendly operation
Hotkey and push-button functionalities streamline switching between systems, making it quick and efficient for daily use. -
Advanced connectivity options
Featuring multiple ports including USB 5Gbps and 2.0 HID ports, the switch easily connects various peripherals for increased productivity. -
Environmental compliance
The switch is compliant with FCC, RoHS, and WEEE standards, ensuring safe use and minimal environmental impact.
- StarTech.com 4-Port Dual-Monitor DisplayPort KVM Switch, 4K 60Hz, 2x USB 5Gbps Hub Ports, 2x USB 2.0 HID Ports, Hotkey and Push-Button Switching, TAA Compliant - 3.5mm Audio, HDCP (P4DD46A2-KVM-SWITCH) - KVM / audio switch - 4 ports - TAA Compliant
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- 4K resolution support, Auto Scan Mode, 8KV ESD Protector (air-gap discharge), 6KV ESD Protector (contact discharge), steel housing, built-in buzzer, push button, EMI/RFI protection, hotkeys
- Power
- AC 100-240 V 1 A
- 10 cm x 25.3 cm x 6.6 cm
- 1.2 kg
- Black
- Localisation
- Japan, New Zealand, North America, United Kingdom, Europe
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3684 x 2160 @ 60 Hz
- Status Indicators
- Port status
- 2 x DisplayPort input , 2 x USB 3.0 input 9 pin USB header female , 2 x USB 2.0 input Type A female , 2 x audio input mini-jack female , 8 x DisplayPort output , 4 x USB 3.2 Gen 1 output Type B , 8 x audio output mini-jack
- Power Device
- External power adapter
- Power Provided
- 3 A
- Voltage Required
- AC 100-240 V
- Electric Current Required
- 1 A
- 0.1 Watt
- Black
- MTBF
- 103,062 hours
- FCC, RoHS, WEEE
- TAA Compliant
- Localisation
- 10 cm
- 25.3 cm
- 6.6 cm
- 1.2 kg
- Shipping Width
- 16.2 cm
- Shipping Depth
- 33.2 cm
- Shipping Height
- 12.9 cm
- Shipping Weight
- 1.4 kg
- Limited warranty - 2 years
- 0 °C
- 50 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £7.41 |
StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £13.82 |
StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £14.83 |
StarTech.com 10ft DisplayPort 1.4 8K 60Hz | In Stock | £20.57 |
StarTech.com 16ft DisplayPort 1.4 8K 60Hz | In Stock | £35.05 |
StarTech.com 2-Port Dual-Monitor KVM Switch | In Stock | £298.54 |
StarTech.com 4-Port DisplayPort KVM Switch | In Stock | £351.85 |
StarTech.com 2-Port DisplayPort KVM Switch | In Stock | £292.80 |
StarTech.com 2-Port DisplayPort + HDMI KVM | In Stock | £288.68 |
