Robust construction
The KVM switch is built with a durable steel housing that ensures long-lasting performance and protection from physical damage. -
High-performance video support
With support for a maximum resolution of 3684 x 2160 at 60 Hz, this switch delivers stunning visuals for an enhanced viewing experience. -
User-friendly operation
Hotkey and push-button functionalities streamline switching between systems, making it quick and efficient for daily use. -
Advanced connectivity options
Featuring multiple ports including USB 5Gbps and 2.0 HID ports, the switch easily connects various peripherals for increased productivity. -
Environmental compliance
The switch is compliant with FCC, RoHS, and WEEE standards, ensuring safe use and minimal environmental impact.
 - StarTech.com 4-Port Dual-Monitor DisplayPort KVM Switch, 4K 60Hz, 2x USB 5Gbps Hub Ports, 2x USB 2.0 HID Ports, Hotkey and Push-Button Switching, TAA Compliant - 3.5mm Audio, HDCP (P4DD46A2-KVM-SWITCH) - KVM / audio switch - 4 ports - TAA Compliant
- Enclosure Type
 - 1U
- Subtype
 - KVM
- Ports
 - 4 x KVM / audio / USB
- KVM Users Qty
 - 1 local user
 - 4K resolution support, Auto Scan Mode, 8KV ESD Protector (air-gap discharge), 6KV ESD Protector (contact discharge), steel housing, built-in buzzer, push button, EMI/RFI protection, hotkeys
- Power
 - AC 100-240 V 1 A
 - 10 cm x 25.3 cm x 6.6 cm
 - 1.2 kg
 - Black
- Localisation
 - Japan, New Zealand, North America, United Kingdom, Europe
- TAA Compliant
 - 2-year warranty
- Enclosure Type
 - Desktop 1U
- Subtype
 - KVM
- Ports
- KVM Local Users Qty
 - 1 local user
- Keyboard / Mouse Interface
 - USB
- Max Resolution
 - 3684 x 2160 @ 60 Hz
- Status Indicators
 - Port status
 - 2 x DisplayPort input , 2 x USB 3.0 input 9 pin USB header female , 2 x USB 2.0 input Type A female , 2 x audio input mini-jack female , 8 x DisplayPort output , 4 x USB 3.2 Gen 1 output Type B , 8 x audio output mini-jack
- Power Device
 - External power adapter
- Power Provided
 - 3 A
- Voltage Required
 - AC 100-240 V
- Electric Current Required
 - 1 A
 - 0.1 Watt
 - Black
- MTBF
 - 103,062 hours
 - FCC, RoHS, WEEE
- TAA Compliant
- Localisation
 - 10 cm
 - 25.3 cm
 - 6.6 cm
 - 1.2 kg
- Shipping Width
 - 16.2 cm
- Shipping Depth
 - 33.2 cm
- Shipping Height
 - 12.9 cm
- Shipping Weight
 - 1.4 kg
 - Limited warranty - 2 years
 - 0 °C
 - 50 °C
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 60 °C
                        StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £7.41 |
                        StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £13.82 |
                        StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £14.98 |
                        StarTech.com 10ft DisplayPort 1.4 8K 60Hz | In Stock | £20.57 |
                        StarTech.com 16ft DisplayPort 1.4 8K 60Hz | In Stock | £35.05 |
                        StarTech.com 2-Port Dual-Monitor KVM Switch | In Stock | £298.54 |
                        StarTech.com 4-Port DisplayPort KVM Switch | In Stock | £351.85 |
                        StarTech.com Dual-Monitor DP 1.4 KVM Switch | In Stock | £389.32 |
                        StarTech.com 2-Port DisplayPort KVM Switch | In Stock | £292.80 |
