Share a keyboard, mouse and dual DVI displays/monitors between 4 multimedia computers. The SV431DD2DUA 4-port Dual DVI USB KVM Switch allows up to four PCs, each with dual DVI video outputs, to share two monitors, one microphone and set of speakers, one keyboard and one mouse as well as two other USB peripherals.
An ideal solution for graphic designers, CAD/CAM designers or educational and financial institutions, the dual view KVM Switch allows you to instantly switch back and forth between dual DVI display PCs at the touch of a button, while maintaining professional level video quality on both monitors. The dual DVI switch also features an integrated USB hub port that allows USB 2.0 peripherals such as thumb drives, external hard drives or web cams to be shared between attached systems - eliminating duplicate peripheral costs.
While both DVI-I (analog mode) and DVI-D (digital only) are supported by the KVM, both source PCs should output the same signal type for proper switching. It is recommended wherever possible to use DVI-D cables across all PC to KVM and KVM to Console connections.
- StarTech.com 4-Port Dual KVM Switch with Audio for DVI Computers - Built-in USB Hub (SV431DD2DUA) - KVM / audio / USB switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Built-in 2-port USB 2.0 hub
- 22 cm x 13 cm x 6 cm
- 1.2 kg
- Black
- 3-year warranty
- Designed For
- P/N: IM12D1500P, SV431RACK, SVA12M2NEUA, SVA12M5NA, USBDVI4N1A10, USBDVI4N1A6
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2048 x 1536
- 8 x DVI-I , 4 x keyboard (USB) / mouse (USB) Type B , 4 x microphone mini-jack , 4 x speakers mini-jack , 2 x DVI-I , 1 x microphone mini-jack , 1 x speakers mini-jack , 2 x keyboard (USB) / mouse (USB) Type A , 2 x USB 2.0 Type A
- Power Device
- External power adapter
- Black
- FCC, RoHS
- 22 cm
- 13 cm
- 6 cm
- 1.2 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Designed For
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £308.45 |
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £232.12 |
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £161.20 |
StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.55 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £23.35 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.88 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.47 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.42 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.58 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £16.93 |
StarTech.com 2 Port High Resolution USB DVI Dual Link KVM Switch with Audio | In Stock | £218.44 |
StarTech.com 4 Port USB DVI KVM Switch with DDM Fast Switching Technology and Cables | In Stock | £219.78 |
StarTech.com 2-port Dual VGA KVM Switch | In Stock | £156.84 |
StarTech.com 4-port Dual VGA KVM Switch | In Stock | £207.93 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £13.92 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £45.71 |
StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display | In Stock | £540.85 |
