This 4-Port USB 3.0 DisplayPort KVM switch lets you control four DisplayPort (DP) computers with a single monitor, keyboard and mouse. The KVM also features 3.5 mm audio and a built-in 3-port USB 3.0 hub.
This KVM switch offers a built-in 3-port USB 3.0 hub that's separate from your HID keyboard and mouse, so you can share USB peripheral devices between each connected computer and avoid the expense of separate equipment. The USB 3.0 hub automatically switches your connected USB devices to the selected computer, saving you the hassle of disconnecting and reconnecting your peripherals.
With support for USB 3.0, you can achieve data transfer rates up to 5Gbps, to ensure flawless performance for your USB peripherals - great for quickly transferring data to external USB 3.0 drives.
Offering support for resolutions up to Ultra HD 4K at 30 Hz, this 4-port DisplayPort KVM switch has the ability to drive large DP displays with ease, making it ideal for graphical applications that require high-resolution video support.
The KVM switch features auxiliary 3.5 mm audio ports that enable you to share independent analog audio, from each of your connected computers, with your desktop speaker set. Independent audio, along with 4K DP video, gives you full multimedia control between different computers, making this KVM perfect for creative professional applications such as video and sound design or editing.
Robust connectivity options
This KVM switch features a variety of interface options including DisplayPort input and output, USB 3.0 ports, and audio input/output, ensuring compatibility with numerous devices. -
High-resolution support
With a maximum supported video resolution of 3840 x 2160, it delivers crisp and clear visuals for demanding applications. -
Efficient peripheral management
The built-in 3-port USB 3.0 hub facilitates easy connection and management of various peripherals, improving overall workflow. -
Temperature versatility
Operates efficiently within a temperature range of 0 °C to 40 °C, making it suitable for both office and industrial environments. -
Compliance with standards
Meets FCC, RoHS, and WEEE standards, ensuring that it is safe and environmentally responsible for users.
- StarTech.com 4 Port DisplayPort KVM Switch - DP KVM Switch with Audio and Built-in USB 3.0 Hub for Peripherals - 4K 30Hz (SV431DPU3A2) - KVM / USB switch - 4 ports - rack-mountable
- Enclosure Type
- Rack-mountable
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB + 3 x SuperSpeed USB
- KVM Users Qty
- 1 local user
- Built-in 3-port SuperSpeed USB 3.0 hub
- Power
- AC 120/230 V / DC 9 - 12 V
- Localisation
- Australia, North America, United Kingdom, Europe
- 2-year warranty
- Designed For
- P/N: SV431RACK
- Enclosure Type
- Rack-mountable
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 30 Hz
- Status Indicators
- Power, select
- 1 x DisplayPort output , 4 x USB 3.0 output Type A , 1 x audio output mini-jack , 4 x DisplayPort input , 4 x USB 3.0 input Type B , 4 x audio input mini-jack , 3 x USB 3.0 Type A
- Power Device
- Internal power supply
- Voltage Required
- Included Accessories
- 4 rubber feet
- FCC, RoHS, WEEE, RCM
- Localisation
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 60 °C
- Designed For
- P/N: SV431RACK
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £240.14 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £287.60 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £22.12 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.38 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.00 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.48 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.06 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.17 |
StarTech.com 4 Port HDMI KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable | In Stock | £310.52 |
StarTech.com 2 Port Dual DP KVM Switch - 4K | In Stock | £245.82 |
StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz | In Stock | £328.22 |
StarTech.com 2 Pt DisplayPort KVM | In Stock | £287.20 |
StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz | In Stock | £83.26 |
StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable | In Stock | £91.46 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £11.55 |
StarTech.com 2 Port USB C KVM Switch | In Stock | £85.71 |
StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch | In Stock | £351.85 |
StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch | In Stock | £450.18 |
StarTech.com 2 Port Hybrid USB-C KVM Switch | In Stock | £37.12 |
StarTech.com 2-Port DP KVM Switch, 8K 60Hz | In Stock | £297.72 |
StarTech.com 4-Port DP KVM Switch, 8K 60Hz | In Stock | £369.44 |
