StarTech.com 2-Port DP KVM Switch, 8K 60Hz
Quicklinx: HFNVWS00 Mfr#: D86A2-2-PORT-8K-KVM
Hurry, only 3 left in stock!
£375.48 ex VAT
£450.57 inc VAT
Share and switch between two USB-A and DisplayPort-enabled computers, using this DisplayPort KVM Switch. Share an 8K 60Hz DisplayPort monitor, a keyboard and mouse, two USB 5Gbps devices, and two additional USB 2.0 devices.
  • High-Resolution 8K 60Hz Video
    This KVM supports resolutions up to 8K 60Hz or 4K 144Hz/120Hz. Daisy chain additional monitors via MST pass-through. The KVM supports ultrawide resolutions of up to 5120x1440 at 60Hz. Ideal for applications such as CAD/CAM, video editing, and content creation. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and greater luminosity.
  • Customizable Switching
    This Universal KVM Switch provides various switching options, including hotkey or push-button switching. Hotkeys allow for independent switching of audio and video, enabling audio playback from one computer while controlling the other. An audible buzzer confirms hotkey input, and LEDs provide a visual status of the selected host.
  • Universal Compatibility
    The TAA-Compliant KVM Switch offers universal compatibility, working with all operating systems, including Windows, macOS, ChromeOS, and Linux. It is also compatible with all hardware platforms, including Intel and AMD.
  • Reliable Performance
    The durable metal housing helps prevent Electro-magnetic Interference (EMI). Overcurrent Protection (OCP) ensures peripherals don't overdraw power, reducing the occurrence of device dropouts or shutdowns.
StarTech.com 2-Port DisplayPort KVM Switch, 8K 60Hz / 4K 144Hz, Single Display, DP 1.4, 2x USB 3.0 Ports, 4x USB 2.0 HID Ports, Push-Button & Hotkey Switching, TAA Compliant - OS Independent, Metal Housing (D86A2-2-PORT-8K-KVM) - KVM / audio / USB switch - 2 ports - TAA Compliant
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Performance
Data transfer rate: 5 Gbps
Push button, hotkeys
AC 100-240 V 1 A
16 cm x 10 cm x 4 cm
600 g
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Performance
Max Resolution
7680 x 4320 @ 60 Hz
Push button, hotkeys, Auto Scan mode, ultrawide resolutions support
Status Indicators
1 x DisplayPort output , 2 x DisplayPort input , 4 x USB 2.0 Type A , 2 x USB 3.0 Type A , 2 x USB 3.2 Gen 1 Type B , 2 x audio input mini-jack , 1 x audio output mini-jack
External power adapter
Power Provided
3 A
AC 100-240 V
Electric Current Required
1 A
36 Watt
4 rubber feet
MTBF
130,000 hours
FCC Part 15, RoHS, WEEE, DisplayPort 1.4, DSC, HDCP
TAA Compliant
16 cm
10 cm
4 cm
600 g
Shipping Width
23.8 cm
Shipping Depth
18.4 cm
Shipping Height
8.9 cm
Shipping Weight
1 kg
0 - 80% RH (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
HFNV StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.74
HFNV StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £15.78
HFNV StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £17.05
HFNV StarTech.com 10ft DisplayPort 1.4 8K 60Hz In Stock £33.78
HFNV StarTech.com 4-Port DP KVM Switch, 8K 60Hz In Stock £442.79
