StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable
Quicklinx: C5SJWS00 Mfr#: SV431DPU3A2
Type: KVM / USB switch
Connectivity: KVM
Ports: 4
Hurry, only 3 left in stock!
£351.01 ex VAT
£421.21 inc VAT
This 4-Port USB 3.0 DisplayPort KVM switch lets you control four DisplayPort (DP) computers with a single monitor, keyboard and mouse. The KVM also features 3.5 mm audio and a built-in 3-port USB 3.0 hub.
This KVM switch offers a built-in 3-port USB 3.0 hub that's separate from your HID keyboard and mouse, so you can share USB peripheral devices between each connected computer and avoid the expense of separate equipment. The USB 3.0 hub automatically switches your connected USB devices to the selected computer, saving you the hassle of disconnecting and reconnecting your peripherals.
With support for USB 3.0, you can achieve data transfer rates up to 5Gbps, to ensure flawless performance for your USB peripherals - great for quickly transferring data to external USB 3.0 drives.
Offering support for resolutions up to Ultra HD 4K at 30 Hz, this 4-port DisplayPort KVM switch has the ability to drive large DP displays with ease, making it ideal for graphical applications that require high-resolution video support.
The KVM switch features auxiliary 3.5 mm audio ports that enable you to share independent analog audio, from each of your connected computers, with your desktop speaker set. Independent audio, along with 4K DP video, gives you full multimedia control between different computers, making this KVM perfect for creative professional applications such as video and sound design or editing.
  • Robust connectivity options
    This KVM switch features a variety of interface options including DisplayPort input and output, USB 3.0 ports, and audio input/output, ensuring compatibility with numerous devices.
  • High-resolution support
    With a maximum supported video resolution of 3840 x 2160, it delivers crisp and clear visuals for demanding applications.
  • Efficient peripheral management
    The built-in 3-port USB 3.0 hub facilitates easy connection and management of various peripherals, improving overall workflow.
  • Temperature versatility
    Operates efficiently within a temperature range of 0 °C to 40 °C, making it suitable for both office and industrial environments.
  • Compliance with standards
    Meets FCC, RoHS, and WEEE standards, ensuring that it is safe and environmentally responsible for users.
Startech 4 Port DisplayPort KVM Switch - DP KVM Switch with Audio and Built-in USB 3.0 Hub for Peripherals - 4K 30Hz (SV431DPU3A2) - KVM / USB switch - 4 ports - rack-mountable
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
4 x KVM / audio / USB + 3 x SuperSpeed USB
KVM Users Qty
1 local user
Built-in 3-port SuperSpeed USB 3.0 hub
AC 120/230 V / DC 9 - 12 V
Australia, North America, United Kingdom, Europe
P/N: SV431RACK
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 30 Hz
Status Indicators
Power, select
1 x DisplayPort output , 4 x USB 3.0 output Type A , 1 x audio output mini-jack , 4 x DisplayPort input , 4 x USB 3.0 input Type B , 4 x audio input mini-jack , 3 x USB 3.0 Type A
Internal power supply
4 rubber feet
FCC, RoHS, WEEE, RCM
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
P/N: SV431RACK
C5SJ StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £246.14
C5SJ StarTech.com DisplayPort USB KVM Switch In Stock £230.07
C5SJ StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £22.32
C5SJ StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
C5SJ StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
C5SJ StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £2.97
C5SJ StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
C5SJ StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.29
C5SJ StarTech.com 4 Port HDMI KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable In Stock £313.33
C5SJ StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £251.98
C5SJ StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz In Stock £336.44
C5SJ StarTech.com 4PT Dual DP KVM Switch 4K60 In Stock £583.16
C5SJ StarTech.com 2 Pt DisplayPort KVM In Stock £301.49
C5SJ StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz In Stock £85.35
C5SJ StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable In Stock £93.76
C5SJ StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.72
C5SJ StarTech.com 2 Port USB C KVM Switch In Stock £77.13
C5SJ StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch In Stock £360.65
C5SJ StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch In Stock £461.44
C5SJ StarTech.com 2 Port Hybrid USB-C KVM Switch In Stock £32.88
C5SJ StarTech.com 2-Port DP KVM Switch, 8K 60Hz In Stock £305.16
C5SJ StarTech.com 4-Port DP KVM Switch, 8K 60Hz In Stock £378.68
Connectivity: KVM
Ports: 4
