This 4-port DP KVM switch combines a 4K 60Hz display with KVM switch control of four connected PC and MAC computers. A simple yet comprehensive solution, this 4-port DisplayPort KVM switch combines 4K (60Hz) digital display capability with seamless KVM control of up to 4 connected PC computers and with Mini-DisplayPort adapters, it is also compatible with MAC computers and laptops, convertible notebooks, and tablets.
The DisplayPort KVM switch supports resolutions up to 4K at 60Hz and can drive one large DP display with ease for maximum viewing space.
Featuring audio and USB peripheral support along with both front-panel push-button and hotkey switching, and offering a small form factor with rear connection ports, this 4-port KVM switch will help to minimize workspace disruptions.
The integrated USB 2.0 hub lets you share two additional peripherals among attached computers as if they were directly connected. Sharing USB peripherals using the integrated hub eliminates the expense of duplicate devices such as printers, scanners, and so on.
If you'd like to mount this KVM switch to your server rack, StarTech.com offers a 1U Rackmount Bracket (sold separately) that turns this KVM into a rack-mountable KVM.
- StarTech.com 4 Port DisplayPort KVM Switch, 4K 60Hz, Single Display, Dual Port UHD DP 1.2 USB KVM Switch with Integrated USB 2.0 Hub and Audio, Dell, HP, Apple, Lenovo, TAA Compliant - Keyboard/Video/Mouse Switch (SV431DPUA2) - KVM / audio switch - 4 ports
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Users Qty
- 1 local user
- 4K resolution support
- Power
- AC 100 - 240 V 0.6 A
- 13.1 cm x 22 cm x 4.5 cm
- 160 g
- Black
- Localisation
- Australia, Japan, New Zealand, North America, United Kingdom, Europe
- 2-year warranty
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3684 x 2160 @ 60 Hz
- Status Indicators
- Port status, power
- 4 x DisplayPort , 4 x USB 2.0 Type B , 8 x audio output mini-jack , 1 x DisplayPort , 2 x audio output mini-jack , 4 x USB Type A
- Power Device
- External power adapter
- Voltage Required
- AC 100 - 240 V
- Electric Current Required
- 0.6 A
- 18 Watt
- Black
- Included Accessories
- 4 foot pads
- FCC, RoHS, WEEE
- Localisation
- 13.1 cm
- 22 cm
- 4.5 cm
- 160 g
- Shipping Weight
- 190 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 40%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 60 °C
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.27 |
StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.57 |
StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £191.45 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £292.14 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £23.32 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.05 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.99 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.83 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.11 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.79 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.63 |
StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable | In Stock | £360.98 |
StarTech.com 2 Port Dual DP KVM Switch - 4K | In Stock | £259.12 |
StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz | In Stock | £345.98 |
StarTech.com 4PT Dual DP KVM Switch 4K60 | In Stock | £599.68 |
StarTech.com 2 Pt DisplayPort KVM | In Stock | £302.73 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.12 |
StarTech.com 2 Port USB C KVM Switch | In Stock | £91.76 |
StarTech.com 2 Port Hybrid USB-C KVM Switch | In Stock | £95.09 |
StarTech.com 4-Port KM Switch, USB Switch | In Stock | £237.73 |
