StarTech.com 4-in-1 USB-C to MDP, VGA, DVI or HDMI Adapter
Quicklinx: DZ79WS00 Mfr#: CDPVDHDMDP2G
£21.36 ex VAT
£25.63 inc VAT
This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C laptop to a VGA, DVI, HDMI or Mini DisplayPort (mDP) display.
Avoid the hassle of carrying different adapters, with a 4-in-1 USB-C monitor adapter. With VGA, DVI, HDMI and mDP output, you can connect your laptop to any display using this multiport adapter.
The adapter features a magnetic retainer that guides the breakout cable into place for quick, secure portability. With a durable aluminum enclosure, the adapter can withstand being carried in your travel bag.
The HDMI and mDP outputs on this USB-C video adapter support UHD resolutions up to 4K 60Hz, while the VGA and DVI outputs support HD resolutions up to 1920 x 1200.
The USB-C adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook, or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices.
The adapter is also available with 4K 30Hz HDMI resolution support, in three colours: Space Gray (CDPVDHDMDPSG), Rose Gold (CDPVDHDMDPRG) and Silver (CDPVGDVHDMDP), so you can choose an adapter that matches your laptop or your colour preference.
StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 2.0 or mDP 1.2 (4K 60Hz), VGA or DVI (1080p), Space Gray Aluminum - 4-in-1 USB-C Converter - adapter - Mini DisplayPort / HDMI / DVI / USB / VGA
Cable
Adapter - Mini DisplayPort / HDMI / DVI / USB / VGA
Max Output Resolution
4096 x 2160 - 60 Hz
Space grey
Connectors
24 pin USB-C - male (input)
Connectors (Second End)
HDMI - female (output) , Mini DisplayPort - female (output) , HD-15 (VGA) - female (output) , DVI-I - female (output)
Displayport 1.2/Thunderbolt 3
Active converter, 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA), 4K24Hz (4096 x 2160) support (HDMI), 4K60Hz (3840 x 2160) support (HDMI), 4K60Hz (4096 x 2160) support (mDP)
3-year warranty
Cable Type
Adapter active converter, 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA), 4K24Hz (4096 x 2160) support (HDMI), 4K60Hz (3840 x 2160) support (HDMI), 4K60Hz (4096 x 2160) support (mDP)
Interface Supported
Aluminium casing, DisplayPort Alternate Mode support, 7.1 channel Surround Sound
Space grey
Adapters & Converters
4096 x 2160
Refresh Rate
60 Hz
Apple MacOS, Linux, Microsoft Windows, Google Chrome OS
Connectors
19 pin HDMI Type A - female (output) , Mini DisplayPort - female (output) , 15 pin HD D-Sub (HD-15) - female (output) , 24+5 pin combined DVI - female (output)
FCC, RoHS, HDCP 2.2, HDCP 1.4
Limited warranty - 3 years
DZ79 StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.24
DZ79 StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £20.33
DZ79 StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £3.73
DZ79 StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £14.11
DZ79 StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £19.68
DZ79 StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £9.27
DZ79 StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £31.58
DZ79 StarTech.com mDP to HDMI or VGA Converter In Stock £8.35
DZ79 StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
DZ79 StarTech.com USB C to VGA and HDMI Adapter - Aluminum - USB-C Multiport Adapter - 6" Built-In Cable In Stock £24.81
DZ79 StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter In Stock £19.36
DZ79 StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD In Stock £11.46
DZ79 StarTech.com USB C Multiport Video Adapter - HDMI or DisplayPort - HDR 4K60 - Display Adapter In Stock £30.67
DZ79 StarTech.com USB C Multiport Video Adapter - HDMI or Mini DisplayPort -HDR 4K Display Adapter In Stock £14.78
DZ79 StarTech.com USB C to HDMI Adapter 4K 60Hz In Stock £12.77
DZ79 StarTech.com USB C Video Adapter 4K 60Hz In Stock £36.71
