Higher contrast & vivid colors
With support for HDR and 4K 60Hz, the USB C multiport video adapter lets you enjoy higher contrast ratios and vivid colors providing a crystal-clear video output. -
Flexible video output
Create a workspace with flexible display options with this?USB C 2 in 1 adapter that lets you connect your?USB C device to a VGA or Mini DisplayPort monitor. -
Tested for guaranteed compatibility
USB Type C video adapter can be used with any USB C or Thunderbolt 3 laptop or tablet. Tested and engineered to work with HP, Dell, MacBook Pro, Lenovo, iPad Pro, Surface, Chromebook, Windows, macOS and ChromeOS as well as 50+ monitors, projectors and large format displays. -
Two-in-one video connectivity with travel in mind
Avoid the hassle of carrying different adapters, with a?2-in-1?USB-C monitor adapter.?The multiport adapter features both Mini?DP?and VGA outputs, you can conveniently connect your laptop to any?mDP or VGA-equipped?display. The?adapter?features a durable aluminum enclosure and can withstand being carried in your travel bag. -
Astonishing 4K picture quality?and HDR
The?Mini DisplayPort?output on this?USB-C video?adapter?lets you harness the audio and?video?capabilities that are built into your computer's?USB-C?connection,?delivering?the astonishing quality of UHD to your?4K 60Hz?display. Plus, the VGA output supports HD resolutions up to 1920 x 1080, ensuring you won't have to sacrifice picture quality when connected to a VGA monitor or projector. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. -
Stylish connectivity for your MacBook, MacBook Pro, or any Laptop
The?USB-C display adapter?has a Space Gray housing and built-in?USB-C?cable designed to match your Space Gray MacBook or MacBook Pro. The?adapter?is compatible with?USB-C DP?Alt Mode devices.
- StarTech.com USB C Multiport Video Adapter, USB-C to 4K 60Hz Mini DisplayPort 1.2 or 1080p VGA Monitor Adapter, USB Type-C 2-in-1 MDP HBR2 HDR/VGA Display Converter, Works w/ Thunderbolt 3 - USB-C 2 in 1 Adapter (CDP2MDPVGA) - video adapter - 15.24 m
- Video adapter
- 4K support, HDR support
- Length
- 15.24 m
- Connectors
- 24 pin USB-C - male
- Connectors (Second End)
- 15 pin HD D-Sub (HD-15) - female , Mini DisplayPort - female
- DisplayPort 1.2
- Space grey
- 3-year warranty
- Video adapter
- Length
- 15.24 m
- Space grey
- 4.4 cm
- 1.5 cm
- 50 g
- Connectors
- DisplayPort 1.2, FCC, RoHS, WEEE, REACH
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 50 g
- 3-year warranty
