StarTech.com 4-in-1 USB-C to MDP, VGA, DVI or HDMI Adapter
Quicklinx: DZ79WS00 Mfr#: CDPVDHDMDP2G
£51.67 ex VAT
£62.00 inc VAT
This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C laptop to a VGA, DVI, HDMI or Mini DisplayPort (mDP) display.
Avoid the hassle of carrying different adapters, with a 4-in-1 USB-C monitor adapter. With VGA, DVI, HDMI and mDP output, you can connect your laptop to any display using this multiport adapter.
The adapter features a magnetic retainer that guides the breakout cable into place for quick, secure portability. With a durable aluminum enclosure, the adapter can withstand being carried in your travel bag.
The HDMI and mDP outputs on this USB-C video adapter support UHD resolutions up to 4K 60Hz, while the VGA and DVI outputs support HD resolutions up to 1920 x 1200.
The USB-C adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook, or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices.
The adapter is also available with 4K 30Hz HDMI resolution support, in three colors: Space Gray (CDPVDHDMDPSG), Rose Gold (CDPVDHDMDPRG) and Silver (CDPVGDVHDMDP), so you can choose an adapter that matches your laptop or your color preference.
StarTech.com USB C Multiport Video Adapter - Space Gray - USB C to VGA / DVI / HDMI / mDP - 4K USB C Adapter - USB C to HDMI Adapter (CDPVDHDMDP2G) - external video adapter - space grey
External video adapter
Bus Type
USB-C
Max Resolution
4096 x 2160
Max Resolution Details
DVI (Dual-Link): 1920 x 1200 at 60 Hz / DisplayPort: 4096 x 2160 at 60 Hz / HDMI: 4096 x 2160 at 24 Hz / VGA: 1920 x 1200 at 60 Hz
HDMI (female connector) , VGA (female connector) , DVI-D (dual link) (female connector) , Mini DisplayPort (female connector)
5.4 cm x 10.4 cm x 1.5 cm
Enclosure Colour
Space grey
3-year warranty
Bus Type
USB-C
Max Resolution
7.1 channel surround sound ready
USB-C cable - 11.5 cm
FCC, DisplayPort 1.2
5.4 cm
10.4 cm
1.5 cm
90 g
Shipping Weight
100 g
Enclosure Colour
Space grey
Limited warranty - 3 years
45 °C
5 - 90% (non-condensing)
DZ79 StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £19.07
DZ79 StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £19.27
DZ79 StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £32.95
DZ79 StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £32.95
DZ79 StarTech.com mDP to HDMI or VGA Converter In Stock £18.08
DZ79 StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
DZ79 StarTech.com mini DisplayPort to VGA DVI or HDMI Adapter In Stock £41.39
DZ79 StarTech.com 4-in-1 USB-C to MDP, VGA, DVI or HDMI Adapter In Stock £51.67
Price Range Ex VAT: 50 - 100
